How do I remove that black sticker on the rear fender on my fatboy lo?
To the OP, I bet you own a black bike right? You are I for a surprise when you pull it off then......it ain't black it is clear.
I only had the dual seat back on for one ride and it left marks on the clear coat, T - Cut got rid of the scuff marks but you wouldn't want to do that too often.
I purchased a roll of protective film and made another sticker which I put back on for when using the dual seat.
The film is about quite thick and has so far been very tolerant to being pulled off and on the fender.
Yep that's why the film is there.....
Yes unfortunately,
Yes, I keep the protective clear film on there for the stock pillion on my bike. I always leave the small stock pillion pad on anyhow. When we are 2 up for longer rides the stock pillion is replaced with a larger more comfy for the wife Sundowner passenger pillion. Since that pillion is quite a bit larger I cut a piece of 3M clear contact paper a little larger than the Sundowner pillion and lay it down over the other piece of protective film. Without that the larger pillion would be sitting on the paint. Comes right up when done with that riding configuration.
I use that stuff anytime I need to temporarily protect the paint from things that my contact it while traveling and strapping stuff to the bike. You can see the film but its temporary and looks better than scratches or scuffs in the paint. Just make sure area is clean before applying.
