Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
• Seats
• Risers
• And much more!
#5521
Technically, you can have the ignition come on just like the CVO with the run switch. Dealer can flash the ECM for it. Then you could just lock the barrel and never worry about it again.
#5522
You mean the LEVER is tight on the barrel of the switch, right?
...but the switch itself is loose in the bracket/grenade?
If that's the case, it sounds like the goofy, tamper resistant castle nut that holds the switch into the bracket is a little loose. Harley sells the correct spanner socket for it. On the other hand, wedgemoose says he just did it with the old "Opened Jaws, Tips of Needle Nose Pliers Trick". That's certainly cheaper.
I bought the special socket from H-D...I think it was 20~25 bucks.
I figured that if I sprung for that Odd-Ball, Tri-Wing, Super Special Socket, I'd NEVER have to use it again, HAHAHAHA!!!!
#5524
#5525
Well, I ordered the Kuryakyn bag and 4 clamps from BoardTracker ($202 shipped); looks like this project is a go!
Once it all gets here, it shouldn't take long to whip-up a design for the hardware. I'll likely make a few extra sets of the side plates (probably aluminum for weight savings), cross bars (aluminum tubing) and hollow, tamper-resistant bolts.
On a side note, does anyone know where I can find some stainless (300-series preferably) 5/16-24 x 3/4" tamper-proof button head cap screws? All the usual places I source hardware only have the tamper-proof stuff in 18TPI. I don't need 3000 of them either; about 50-100 would be fine.
-WRM
#5526
-WRM
Jim G
#5527
dabomb6608 (03-28-2017)
#5528
Handlebar Mount Auxiliary Power on a Breakout
I'd like to mount an auxiliary plug to the handlebars and place another in the saddlebag. Is this something I can do just by purchasing part HD part #69200970 or is this something i should have the dealership install? I could not find any detailed posts discussing this on a Breakout. The directions say the tank must come off?
#5529
What are you trying to power up? Just your phone? There are cleaner ways to do that
#5530
Hey everyone, new to the forum but I have taken the time over several weeks to read all the posts here. I bought a 2015 Breakout in August 2016 and I love it. That being said I have a couple questions for the long time members and tech guru's here. I am planning on installing a set of Vance and Hines Big Shot Staggered pipes and. DJ Power Vision tuner. I know about Nostradamus' info on his install using V&H part 17933. Unfortunately that part number is no longer available and they are using a universal fit # of 17939. When I called Fuel Moto today I wanted to be sure I could get a good map for the Power Vision, since the manufacturer says these pipes do not fit the breakout. The tech went on to say that they won't even order pipes for me if the manufacturer says they don't fit my model.
So here's the big question...if I order a set of pipes for a 2016 Softail Fatboy and a Power Vision for the same bike will I be ok with mapping or should I order my pipes and tuner separately and get the tuner mapped for the breakout?
