Confusion on Lubrication levels....can someone clarify?
I have a 2005 Softail deluxe and changed the oil, transmission and primary lubricants this weekend. There seem to be some inconsistencies and just wanted to get the word from others that should know:
On the engine oil, some documentation says the oil should be at the fill neck weld level when cold.....but if that is the case, when the dipstick is inserted it shows being way high. What am I missing here?
The transmission is pretty straight forward. My HD shop suggested using belray in the transmission.....any thoughts on that?
On the crankcase oil, the manual says to add 26 oz of lubricant, but it also says you should be able to see it through the opening, and it even says you can have the lubricant as high as the lower edge of the opening. It takes a LOT more to reach that level.....so how much should be added?
Sorry....just want to make sure before I drive it again all levels are appropriate, but there seems to be confusion to me.
Thanks ahead of time.
Looking forward to learning a LOT from you guys here.
I follow the manual, but the 26 oz and the visible through the opening and almost to the bottom edge are not even close to the same amount...
The level on the dipstick is different when it's on the jiffy stand than when it's upright. The owners manual with my 02 Heritage says to check the oil in the upright position.
This is my routine, which I go through every time I get gas. When finished filling the gas tank I remove the oil dipstick, wipe it off , then put it back in.
I get on the bike and raise it upright level. Then put it back on the jiffy stand and check the level. As long as the level is above the low line I know it's ok.
Deluxe
I have a 2005 deluxe forget about the weld mark change your filter and add 2.8 quarts to the crank case take it for a ride get it hot then check it top off if needed I never have to add any thing 2.8 does it. Primary is 26 to 28 if you do not want to pull the derby cover to see the level it's in the manual. On the tranny you stand the bike level and check it when you catch the first thread on the stick in tranny add if needed to the mark on the stick. Over filling your crank case will cause it to come out your breather to many newbies do this better to start with less and add then over fill
I follow the manual for adding fluids. Buy yourself a set of baby bottles at WallyWorld and use them to add fluids. They are under $5 and they have Oz. marks on them and make it a snap to measure out 26oz's. Just use a sizzors to snip a piece of the rubber nipple off and you can squirt the fluid right in without a funnel!!
