Extended Forward Controls For Breakout
#101
#102
I would't think so but I'm no pro powder coater. I'd look for someone to remake the factory line in black plus the extra length you need or you could always cover the Ness line with some heat shrink tubing. Can't believe that Ness doesn't offer the lines in black or chrome...
#103
#104
Damn ... one more thing about the Ness brake line and the H-D banjo bolts. The banjo bolts are two different diameters. So that means that the copper washers included in the Ness kit are two different sizes. Be sure to use the small washers up front...you'll need the bigger washers for the rear banjo bolt. Guess how I discovered that
#105
#107
Got the banjo fitting bolted up to the ABS and ran the line to the front of the bike. What a pain in the butt but that was. At least the hard part is done. I 'll put the bracket on tomorrow after work. I put the fender and exhaust back on. I'm done for today. I got a late start. I went riding this morning and didn't even plan on doing this today. Rained all afternoon and got bored and started.
#108
#109
Glad I could help.
You know... I'm going to look into modding the factory rear brake lever. I'd rather have a peg to match the shifter. If a replacement is cheap I'm going to do it. Cut, grind, weld and then off to be re-chromed.... easy-peezy.
Anyone out there have a take-off they want to sell?
#110
Finally got the brakes bled. I never turned the switch on the bike from taking off the first bolt until I bled the brakes. No ABS light. Did a little test of hitting the back brake hard and worked fine.
It is a big difference with the pegs out 3 inches. I like it. I felt like my knees were to high riding before. The mod is worth the money (expensive to just move your feet/legs out).
Thanks for the help! Would have been a little harder without being able to read and learn from this thread/board.
