Extended Forward Controls For Breakout
This mod has proven to be a little more difficult than I thought. But we got it done. Apparently the brake line kit that comes with the AN Kit doesn't work. We had to make our own lines and modify the tee where the ABS ties into the brake line. I don't know if there was a change between the 13 and 14…..But I can tell you now. If you have a 14…..the stock setup will not work without some modifications. We took the tee, cut off the line going to the forward control….welded it shut, then drilled and tapped the tee for a new fitting that goes to the forward. I do like the new forward position though. It was worth the effort.
