Oil Pressure 0psi at idle.
I have a 2005 FLSTCI and have just upgraded to a Screamin eagle hydraulic cam chain tensioner and oil pump and fitted an oil pressure gauge, when I started the bike the oil pressure was up around 40psi, as the engine warmed up the pressure started to drop to a point where at idle the gauge reads 0psi, if i open the throttle a little the pressure goes up to 10psi, is 0psi at idle with a warm engine something to be worried about?
Does your oil light come on, if not you probably have pressure at the sensor and the gauge is bad.
Uberjason
Milwaukee Eight (M8)
04-23-2019 08:25 PM
