Turn signal Relocation with Fairing
I have a Dead Center fairing on my Fat Boy Lo, and absolutely love it, the one issue I have is it pretty much blocks my turn signals from view. Considering how oblivious cagers already are, I don't need to make it worse. As you can see by the attached photo, they are hard to see. The pic was taken in a darkish area, with the left turn signal on. Anyone have any suggestions on a way to relocate the turn signal to a more visible area?
Are the blinkers we see in stock location or are those in the fairing itself? hard to tell......
Anyways, a quick search will get you what you are looking for on here as it has been covered several times. there is a very good write up on it by Misbehaven here: https://www.hdforums.com/forum/softa...fatboy-lo.html
should be no different for your 2014
I actually saw the exact turn signals mentioned in the write up, but if you look at the auction in it states the following.
* Kit is for 2009 Harley's & earlier model years AT THIS TIME due to HD changes in the turn signal wiring (model yrs 2010-2013). CURRENTLY the kit DOES NOT come in black, chrome only.
Yup, stock position, on the handlebars near the clutch / brake. I actually saw the exact turn signals mentioned in the write up, but if you look at the auction in it states the following. While I want it in black, its not a deal-breaker. The wiring change is, and I am guessing is going to continue to be a problem with any pre-2010 solution.
Also check Memphis shades or the company that made your fairing. They usually offer the relocation kit. I know Memphis shades does as that is what I have looked up for cold weather riding as I don't care too much for windshields
The one I have doesn't have a way to adjust for it, your sort of on your own.
A friend pointed , and it looks like a viable option. Anyone know anything about them / have used it? How bright is it compared to stock? How noticeable are the signals? How hard is it to get installed?
