Removing Frame Horn help
Old 01-15-2014, 01:24 PM
SwiftyBKells's Avatar
SwiftyBKells
SwiftyBKells is offline
Default Removing Frame Horn help
I can't seem to loosen my stock frame horn bolts. I've already bent 2 sockets & have practically stripped one of the bolts. Anyone else run into this? Advice?
Old 01-15-2014, 03:39 PM
Motown Strag's Avatar
Motown Strag
Motown Strag is offline
Not exactly sure which bolts you mean but can you get a torch in there to heat it up a little? That usualy helps.
Old 01-15-2014, 08:45 PM
SwiftyBKells
The chrome pieces that hold the rear fender on...a torch would ruin the chrome.
Old 01-15-2014, 09:23 PM
08Nighttrain's Avatar
08Nighttrain
08Nighttrain is offline
They make a product that freezes the bolt by spraying super cold air out of an aerosol can this shrinks the metal and works just like heating it would (opposite effect but same principal) and won't hurt chrome although I can't imagine why you wouldn't want to powder coat them black once you got them off.
Old 01-15-2014, 10:34 PM
SwiftyBKells
I've got a black & chrome set but haven't made up my mind yet. Does a typical auto store carry that freeze stuff (autozone, napa, etc.).
Old 01-15-2014, 10:47 PM
CagelessRoy's Avatar
CagelessRoy
CagelessRoy is offline
There's a product called "mouse milk" that I used on stubborn bolts. Worked like a charm each time. If you have any aircraft supply shops around they usually carry it.
Old 01-16-2014, 06:32 AM
08Nighttrain
Yes AutoZone carries it. I can't remember the name exactly but you will know when you see it.
Old 01-16-2014, 07:17 AM
hdgzr's Avatar
hdgzr
hdgzr is online now
Received 1,869 Likes on 595 Posts
I've used this with success on stubborn bolts also. Most auto parts stores carry it, Home Depot, etc.
Attached Thumbnails Removing Frame Horn help-f425dd0b-872e-43cd-aa90-4a8d5637331f_1000.jpg
Old 01-16-2014, 11:17 AM
SwiftyBKells
I've already tried drenching these things in liquid wrench. I'm gonna give the stuff 08nightrain is talking about a go. hopefully that'll get the job done. ill let ya know.
AKFXD
12-09-2015 09:32 PM
Amber2014
06-23-2015 11:07 AM
pcbunn
05-22-2010 07:16 PM
hogster1961
09-03-2009 06:52 PM
Nellybelle
08-27-2007 01:14 PM
Quick Reply: Removing Frame Horn help
