Tuner Cable Info - 41000018
Guys,
I posted over in the tuning forum almost a week ago and still have not had any luck. Hopefully this section sees more action and someone can help me out.
I'm looking for a pinout of the newest tuner cable that harley sells. The one that has a DB9 on one and and the 6 pin deutsch connector on the other end. I'm hoping that someone who has this cable already can use their multimeter to ring it out and draw me a quick map of the cable. Hoping to make up one of my own.
Thanks in advance!
Thanks in advance!
Have you the tuner cable pinout??
Guys,
Thanks in advance!
Thanks in advance!
Thanks a lot in advance.
Found this on http://forum.milwaukee-vtwin.de/
Geschrieben von MrJimmy am 25.08.2014 um 09:40:
Moin,
so Kabel kam an. Wenn jetzt kein Fehler beim durchklingeln passiert ist und wir annehmen, dass der/die Stecker so aufgebaut sind:
Dsub9:
5 4 3 2 1
9 8 7 6
DeutschStecker DT06-S
4 1
5 2
6 3
dann wäre die Belegung für den 6 poligen Stecker folgendermaßen (Pin 2 +3 sind tot)
DSub9 DT06-S
9 1
3 4
1 5
4 6
- 2
- 3
Viel Spass beim basteln
Greetz
Translated by Google Translate:
Written by MrJimmy on 25/08/2014 at 09:40:
Hello,
so cable arrived. Now, if no error happened when by ringing and we assume that the / the connectors are constructed:
Dsub9:
5 4 3 2 1
9 8 7 6
German plug DT06-S
4 1
5 2
6 3
then the default setting for 6 pin connector follows would (Pin 2 +3 are dead)
DSub9 DT06-S
9 1
3 4
1 5
4 6
- 2
- 3
Have fun tinkering
Greetz
Moin,
Dsub9:
5 4 3 2 1
9 8 7 6
4 1
5 2
6 3
DSub9 DT06-S
9 1
3 4
1 5
4 6
- 2
- 3
Greetz
Hello,
Dsub9:
5 4 3 2 1
9 8 7 6
German plug DT06-S
4 1
5 2
6 3
DSub9 DT06-S
9 1
3 4
1 5
4 6
- 2
- 3
Have fun tinkering
Greetz
