Did Vance and Hines just blow away all tuners on the market?
#132
They only just rolled it out in the last few years, and finally on all models in 2014:
"..Harley-Davidson is now using Can-Bus to monitor operation of the headlight, taillight, brake light and the signals in some cases on some 2011- 2013 models and then beginning with all models in 2014..."
..and V&H kinda did advertise that...
Their FP3 homepage says: "..FuelPak FP3 - for 2014 Harley-Davidson models..."
Did you call and talk to V&H Sales/Tech before you ordered it?
#133
#134
Actually it says it is for can-bus softail models 2011 thru 2014. Nowhere in any advertisement does it say auto-tune only works on canbus models with 12mm O2 sensors 2012 -2014. Definitely misleading. Once you install you get a surprise message, No Auto-tune function this model. Here is the link to models and years for FP3 http://www.vanceandhines.com/store/vtwin/fuelpak/66005
#135
Straight from the horse's mouth...
To avoid any confusion I emailed them about the FP3 and this was the response I got:
My original question:
Have heard conflicting reports about FP3 and want to get the truth. Will the FP3 work on a 2012 FLSTC and if so does the Autotune function work with this year & model as well? I plan on replacing exhaust and air filter but was unsure of what tuner to get because I was not real crazy about the idea of letting someone literally rev my bike to 6200RPM just to tune it, nor spending upwards of $1000 on the tuner that replaces your factory ECM with new O2 sensors that have to have new bungs welded in pipes.
I have seen bikes being tuned and the guys were not kind to the motors. I like the idea of having the ability to run unit with autotune enabled and let it tune to my riding habits. Mine has never seen anything past 3500 RPM and I am looking to get rid of decel popping and engine/exhaust heat only. Not real concerned with huge power gains, just that the engine runs cooler. The only mods I will ever make will be slip-ons and high flow air filter, and the only reason I am doing that is because everyone has told me that you have to have high flow air filter & pipes before you can tune. If it was OK to just use your product with a bone stock bike I would because I like the sound of the factory pipes, never cared for loud pipes anyway.
Thanks for your time...
Their response:
Steve,
You will be able to use the FP3 in auto tune, however if you have a basic set up like slip ons and intake we have canned maps that you will be able to use as well.
Thank you,
VANCE & HINES
13861 Rosecrans Ave. Santa Fe Springs, CA 90670 t.(562) 921-7461f.(562) 802-0110
Their response:
Steve,
Thank you,
VANCE & HINES
#136
You can absolutely tune a stock bike and notice a change in performance. Not sure who told you you need to be modded prior to tuning.
Their response:
Steve,
Thank you,
VANCE & HINES
Their response:
Steve,
Thank you,
VANCE & HINES
#137
Autotune problem
I installed the FuelPak FP3 a few days ago and I've been very pleased with the result. Runs cooler, better throttle response, no decel pop and tick-over is more stable; all this from the V&H canned map.
Running autotune presented problems which I eventually overcame; here's how. After flashing the canned map I decided to run the autotune function, I was told to select which map to autotune and I selected the canned map and the FP3 went ahead and flashed the ECM.
This is where it went wrong, the bike would not start, it turned over but would not fire, behaving as if it was out of fuel. My first action was to re-flash the canned map but the FP3 was now in autotune mode so would not allow me the access any installed maps. I selected autotune again and then selected to finish autotuning, I was now able to access the installed maps. I re-flashed the V&H canned map which worked I could now start the bike.
So what went wrong? The following day I attempted to run autotune again after using some of the other functions of the FP3, this produced the same result but this time I noted a message saying "the ECM flash was not completed", once again the bike would not start. After re-flashing the V&H map again and getting the bike running I turned off the engine and switched off the ignition. After waiting 30 seconds I turned on the ignition, waited a further 30 seconds for the FP3 to boot and then run the autotune option, this time the FP3 reported the flash was successful and the bike started.
In summary, it seams the FP3 autotune feature needs to be run without having previously run any other of the FP3 features for that session. My guess is this is an issue with the internal RAM of the FP3.
Can anyone confirm this?
#138
#139
I am currently working on modding a set of factory mufflers and will see how it goes. Like the sound, just not the exhaust heat.
#140
I have been running the FP3 for a while now and am very pleased. I have V&H Short Shots with quiet baffles and DK air cleaner. With the canned map, my bike runs cooler, smooth, seems to have more power and most important to me - no decel pop. I just shift when it feels right so I usually am not exactly sure what gear I am in. Since installing the FP3, I find I am in 6th gear more than ever before. I am happy with the canned map so I took the FP3 off my bike and retired it it my parts shelf. Life is good.
