88" hydraulic cam conversion upgrade
For those of you still running 88's or have in the past......
Im doing a cam conversion on my 02 Heritage to the (07 & later) hydraulic cam plate with Andewrs 21n cam.
Ive read all the threads i could find. Im using the parts list on the Andrews web site, with one exception.....I bought the #62400004 Screamin Eagle oil pump. It was cheaper than the stock oil pump (#26037-06).
Is there any reason why this #62400004 Screamin Eagle oil pump would not work for this conversion with the STOCK (07-later) cam Plate #25358-06??
The reason Im asking, is that i just came from the dealer to get some gaskets. The parts guy suggested that this pump would not work because it would cause varying oil pressure. Im not sure he understood what I was doing, because he was trying to sell me the Sceamin Eagle billet cam plate at $500.
I just called Andrews, they are out till Monday.
Has anyone had any experience with the upgrade and this pump?
Thanks for chimin in!
im also interested
The parts list on the Andrews website is not complete unless they have recently updated it. PM me your email address & I will send you a complete parts list if you are interested.
From my reading on another forum a guy said he used screamin eagle pump 62400001 on your application
jdm65, i have a 2002 road glide and im also interested in this mod, way lesss expensive then the 900.00 cdn dollars our canadian dealer is asking, sent you a contact something, but cant find where to send msg, probably because im new, im on v-t... do a lot more, any info on how to use a 25358-06 plate on a 2002 and the right parts, specially the pump would be gratly appreciated, thanks
I have read several posts on various forums where people have claimed to use the SE Oil Pump #62400004 with the standard '07 up cam plate with no issues....
2nd hand info to be sure, but you can search and see for yourself. Then decide if the posts seem credible..... personally I believe them, can't see how it wouldn't work..
danny
Softail Parts
10-08-2011 06:26 PM
danny
Touring Parts
10-08-2011 06:24 PM
