2011 Deluxe removal of oil tank - advice!
Hi all,
I removed the stock chrome oil tank from my 2011 Deluxe yesterday, using the Service Manual. It was pretty straightforward until the last step, "remove oil tank from right side of vehicle."
It was a PAIN to get thank tank out, mainly because of the fuse block and wiring to the rear of the tank, in front of the mud guard (which I removed per Service Manual).
I had to lift up the wiring harness (wrench out is more like it) that circles the frame above the oil tank in order to get the tank out. It felt like I was really yanking on the wiring to make clearance for the rear of the oil tank to clear the frame and wiring to get it out.
Now I'm worried I'll have to really tweak stuff to get the tank back in after I PC it. Did I miss a step, or read the manual wrong? Or is it a PITA normally?
Thanks
Thanks
Oil tank
Just did the same thing, take it easy unplug as much as you can and cut zip ties, I also removed the seat/ frame post to give me more room, lift up harness as far as you can ,lift tank and pull out and rotate towards the back at the same time ,should pull right out!
