Led accent lighting trouble
Ok, I have done this before but that was on an Ultra, but I didn't have problems before, so I turn to you electrical experts here. So I'm in the middle of hooking up some engine led accent lights on the 07 Deluxe. Using HD part # Auxiliary Accessory Switch Housing kit 70213-02C, with Auxiliary On/off Switch kit 71718-02, for easy access to be right on the bars. So I run an extended wire to be able to make my connections under the seat. My plan was to go direct to the battery, power from the switch and power for the led to the positive and both ground for the switch and led to the neg side. I am getting a huge sparking and even fried one of my leds. Now I used to have it hooked up in my Ultra to a relay with an inline fuse in it and direct to the electrical accessory adaptorand grounded elsewhere besides the neg side. Really don't have room for a relay on the deluxe and for extra wiring all over the place. The switch is good hooked it up to the spot lights and works fine there. Any help would be helpful.
Sparks and flash!
this is how i did my lights and they work fine with no shorts.
take all of the positive wires from the led's and hook them up to the switch. run the positive wire from the switch to the battery.
then take the negative wire from the led's and run to the negative terminal on the battery. dont hook up the negetive wire from the switch to anything
hope that helps
hope that helps
hope that helps
hope that helps
hope that helps
hope that helps
Sorry guys, but there is NO negative wire on a 12 volt switch. A 12 volt switch has two wires.
One goes to the power source- 12 volt battery
Second wire goes to the device you are switching- led lights (positive side)
Your negative wire (chassis ground) will go to the negative side of the led lights
OP, I hope you don't get offended but if this is not easily understood you really need to consult with a friend that has electrical experience. You can really do some damage if you're not careful.
If you have two wires on your switch and one has nothing hooked to it what is the switch "switching"?
yep what he said
Hope this doesn't confuse the issue, but IF the switch is a lighted switch (one that lights up when you turn it on), it will have three connections; one goes to the battery +, one goes to the LEDs, and one gets grounded (to turn on the light in the switch). There should be markings to differentiate them. These used to be really popular items in auto parts outlets...
