Question for those with 2" tank lift (with deluxe option)???
I put the 2" tank lift on my bike with the deluxe option (which raises the rear of the tank 1/2"). I am on my 5th tank of gas and it seems that when my gas gauge reads between 1/2 and 1/4 of a tank, my bikes starts to spit and sputter like it wants more fuel. Now im wondering that since the fuel pump is right under the speedo in the center, and not in the back where the fuel line is, that when the fuel slushes around in the tank, it is causing the fuel pump to not get the fuel it needs.
Has anyone else had this issue with the 2" lift? Its happens twice and both times when I filled the tank up, it went away.
I love the way it looks but depending on what kind of answers I get here, it may have to be removed.
I went with the 1.5" lift back in December. No sputtering or problems. Just rode the 3 sisters which have a lot of steep grades and twisties.
FYI the low fuel running light now comes on with 1 gallon remaining and the fuel gauge is just above E.
Tried the .5" deluxe but couldn't get the seat to fit.
How many miles do you have on a tank at that point. Also, I had this issue. It was a hole in the fuel line. It's a pretty common problem. It spits gas that's supposed to be going to the motor back in the tank so not all the fuel that is supposed to be getting there is.
How did you determine you had a hole in the fuel line? Did you just pull the fuel pump and then see it?
The best way to determine how much fuel you have especially with a tank lift, is with the Miles to empty. Harley fuel gauges are notoriously unreliable, a tank lift just exaggerates that problem.
If you are still having this problem even when going by the MTE and you know that you have plenty of gas, I would start looking into other possible causes.
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
www.DKCustom.com
662-252-8828 Voice
