I had to tighten my shocks to full stiffness so that I wouldn't bottom out over big bumps in town or pretty much most bumps on the interstate. That was at 240. I had them adjusted back then so now that I'm down to 190 I couldn't tell you if the ride would be any better at stock damping.
Not trying to thread jack you but I was wondering if anyone had ever used the eBay lowering kit? It's just a bolt setup I believe.. Not really sure but it was only like $14 so I figure it couldn't hurt to ask about them. I'll spend the $80 on the dead creek setup but if the $14 ones are just as good then I'll get them and keep saving for the shotgun shock. And another question while I'm here lol... What's the difference between the progressive original kit and the drop in kit other than the obvious about not needing to disassemble the front shocks. Should I spen the extra couple bucks and not need to disassemble or is it not worth it.
The Dead Creek is easier to install. With the bolts you need a press or other improvisation (I used my lift, a metal fence post, a book, a 2x8, a door handle drill bit, and my garage door header) to disassemble the shock. I just used the "drop in" for the front because I had no reason to disassemble. If I was changing seals or powdering the lowers, I probably would have done the other. Despite what the install video shows on the Dyna, the install for the softail is not so drop in.
just did a 2" drop on the deluxe today. used the kit from softailloweringkit.com. everything worked as should and it came with great instructions. also has the option to choose between 1.5" and 2'' drop.
before
after
A great improvement!!! looks great thanks for the pics!! How does it ride?
Damn that camera needs taken out to the backyard and
