Heritage Classic and Lindby rear Linbar
Old 04-17-2014, 07:08 AM
Rocker_Dan's Avatar
Rocker_Dan
Rocker_Dan is offline
Here's a reference shot
May not help but there's plenty of room
Old 04-17-2014, 08:18 AM
NDBadlands4-2's Avatar
NDBadlands4-2
NDBadlands4-2 is offline
Looks like it uses the passenger peg mounts? Can you use them and keep the rear pegs?
Old 04-17-2014, 09:26 AM
pipeyeti's Avatar
pipeyeti
pipeyeti is offline
They take the place of the pegs
Old 04-18-2014, 06:42 PM
yzergod's Avatar
yzergod
yzergod is offline
Pipes stacked (together) measure 5 1/8". Each one of the pipes are 2.5" OD. The top is about 1/4" from the Lindbar, the bottom maybe 1/16th. HTH.
Old 04-18-2014, 10:03 PM
pipeyeti's Avatar
pipeyeti
pipeyeti is offline
Looks tight but it works. Now I need a set.
Old 04-18-2014, 11:45 PM
yzergod's Avatar
yzergod
yzergod is offline
Something I noticed in Rocker_Dan's picture above... his is the second set-up I've seen now with cholos and the Lindbars are opposite of how I have mine mounted. I mounted mine identical to the pictures on the Lindby site. After I saw the first picture, I took mine off and reversed them and could NOT get them to fit. They fit around the pipes, but I could not get the bolts/holes to line up enough to get them mounted. I thought about reaming out the bolt holes a bit to allow for adjustability and think that regardless of how they are mounted, if you reamed the bolt holes it would allow for slight adjustability enough to keep the Lindbars off the pipes.
Old 04-19-2014, 12:26 AM
kblhd's Avatar
kblhd
kblhd is online now
Yzergod,
Thanks for taking the time to post all the pictures. Another case of a supplier saying something wont fit when it fact will.
Old 04-19-2014, 10:32 PM
yzergod's Avatar
yzergod
yzergod is offline
You sir are welcome! I appreciate the acknowledgment. My pleasure to help.
I did clean the whitewalls and wax the **** out of it today after noticing the layer of dust on the pipes in that photo. As I did, it occurred to me that I never even bothered to check if the Lindbars would fit with the V&H pipes. I'm sure I've seen pictures of them on other bikes. I also didn't put any thought into if the pipes would rub or rattle making contact. But, I haven't had a single problem with them. I did have to take the rear pegs off, but I put the Lindbars on for protection. With the front crash bar and these Lindbars,the bike should fair well when it gets dropped on it's side. The Mrs. is a member of an all women's precision stunt performance MC.
csbreeze
10-17-2010 02:23 PM
Adrien7910
01-30-2010 02:10 PM
Lindsay227
01-27-2009 06:12 PM
mrs03
03-23-2008 09:27 AM
Navychief
09-06-2007 10:24 AM
Quick Reply: Heritage Classic and Lindby rear Linbar
