Heritage Classic and Lindby rear Linbar
04-14-2014, 07:58 PM
Anybody running the Lindby rear Linbars on a Heritage Classic with Vance and Hines Long Big Shots?
04-14-2014, 08:21 PM
Close... except the rear Lindbars are on a Deluxe and the pipes are V&H Long Shots.
04-14-2014, 09:47 PM
How much clearance do you have with the Long Shots?
04-15-2014, 07:15 AM
I was wanting to install them but everything I can find says it will not work with 2.5" pipes V&H long shot bigs are 2.5
04-15-2014, 01:32 PM
The heat shrouds on big shot longs are 2.5" I called lindby this morning and was told now way not enough clearance
04-15-2014, 07:12 PM
Well the one side should fit, may order a set and see what needs to be modified to make the exhaust side fit.
04-15-2014, 11:44 PM
Was tight, but it fit. Not sure the difference between the Long Shots & the Long Big Shots.i can snap a pic or two tomorrow if you want...
04-16-2014, 07:38 PM
Pictures would be great. Also your pipe size and clearances to Lindby bars would be helpful.
04-16-2014, 10:43 PM
There is a 100 th anniversity Fatboy on EBAY with what sure looks like big shots and Lindby's. Item 141258211146.
04-17-2014, 06:42 AM
Sure looks like it to me also. I wonder if they touch if so that could be a problem with rattling and heat transfer. His photo doesn't have a good shot.
