Why does my front brake suck?
I have read that HD recommends that you change your brake fluid every 2 years. Mine never has been done since i have owned it and doubt it ever has been changed. DOT 4 is worse because it has a habit of drawing moisture. Softail front brakes are also not known for their stopping power either.
you have to remember that regular vehicles have four wheels with brakes that are 2-3 times the size of bike brakes and all work together with power assist to build more pressure.
if you have a solid brake lever and don't have any mushy/soft feel to it, I would flush the fluid and see how it feels after that. when flushing the system, don't get your self in trouble and let the reservoir run dry allowing air into the fluid passages.
I have a 07 FB and you do have to squeeze a little harder to get decent braking action. I attribute it to being a single caliper manual brake system.. just like my 67 car.. manual brakes require more force from you to work.
Maybe a master cylinder with a larger bore is the answer for single caliper systems.
IMHO Soooo many Softail owners buy their bikes used and don't have any Idea of the maintenance of them prior to their owning them. Nor do they know whats been done or how they were ridden or what's been done....
not another Plus for buying USED....
If your BRAKING system is fugded up.... Then Fix it... U know it aint right,, but in MY 7yrs and 47k miles the braking system on our 07 Heritage has worked perfect or fine for me. I can actually make the front tire squeal If I want too..
I've rode the flats of Indiana and the hill and curves of the Dragon... And I've never once had a PROBLEM of front Brakes.....
If your having an Issue.. Then Get you whole system checked out.... by Someone who know's what the Freak they've doing...
That's IMO the problem,,, tooo many bikes have been worked on by owners that don't know WTF they are doing and others that just ride them and only change the oils..
And that's why some in here are having an ISSUE.. with their Bikes.....
Working on your bike ain't Rocket Science,, it just takes a real Wrench who knows How to do the job...
That's one of the many reasons I won't buy a Used bike unless I Know the complete history..
The caliper on a Softail is very, very simple. Get a seal kit, some appropriate brake fluid, the manual, and get to work. Shouldn't take more than an hour or 2. A Mighty VAC is handy for bleeding as well as compressed air to get the pistons out. I rebuilt mine a couple months ago and can't believe the difference it made. I used EBC's new V-Pads in the front and it has never stopped better.
+1 My front brake SUCKED from day one! Switched to Lyndall Racing pads which helped some. Have a 13" rotor and 6 piston PM caliper now and swear by it. Even stopping a big 26" wheel is no problem.
I also did not like the stopping power of my stock front brake on my 2013 Heritage. I purchased and installed a four piston Brembo brake caliper and it made enough difference that I will leave the back stock. The stopping power (I have ABS) is much better.
http://www.ebay.com/itm/Brembo-brake...c98f6e&vxp=mtr
My 1990 softail was the first Harely I ever owned and the first Harley I ever rode. I also immediately noticed that the front brake was way under powered with that single disk. When I inspected the brake it appeared to be in proper working order and with good pads, it just sucked.
I said I bet this thing will really stop with a nice big dual disk frontend.....so I bolted on a GSXR 1000 frontend!!!!!!!!!!!!!!!!
Now before everybody yells at me, I am just kiddin. I dont expect you to bolt on a gixxer frontend. I would do as some of the the others suggested and do a rebuild kit. They are pretty cheap and easy to do. Hardest part is bleeding them when you are done, but you can get a little bleeding tool at any auto parts store. If the rebuild doesnt do it, I guess they offer dual disk systems, go with that.
Scratch all that, that bolt on brembo in the prior post looks like a great solution!!!!!
