HID install. WOW!
#51
#52
I purchased a kit off eBay about a year ago for $38 after reading a write up by Motown Strag. It was a 35watt HID Motorcycle Hi-Low H4 6000k with slim ballast. I also added a 10 second delay relay purchased from Retro Solutions off eBay. I wired the relay into the Hid harness. I wanted to still be able to just stop and purchase a H4 bulb if the hid went out on me. The hid setup came straight from Hong Kong. I am adding a pic of how I wired the relay.
#53
Thanks
#54
#55
#57
My thoughts...
I think its a bad idea to install this HID kits in to factory reflector housings...period. That goes for both cars and bikes. That fact of the matter is that even though you can adjust the angle of the oem reflector housing on a bike and car, there is still the stray light that will leak out and blast on-coming traffic. These HIDs were originally installed in projector housings for this very reason...as the projector gives the light exact cutouts and doesn't use reflective properties to do so. I can understand wanting to be safe as a motorcycle rider, putting out as many lumens as possible to see and be seen. Just take into consideration that you will most likely be dazzling on-coming traffic with your lights...and not in a positive way.
#58
#59
Many lights are marketed with "HID" in the advertising--they are not all HID's.
HID "bulbs" aren't really a bulb in the traditional sense, because there is no filament that gets hot and glows to make the light shine. They are more of an arc chamber in the middle of a thin glass tube--no filament.
The energy needed to begin and maintain the arc requires certain modifications to any standard vehicle's lighting system. These items are usually found all together in the kits described above, in various configurations.
One thing that they will all have though, is a ballast for each light. With some designs (Phillips PHID's, for example), the ballast is integrated into the back of the light housing, but these types do not fit into existing headlight housings without severe modification. They work well as an external, stand-alone spotlight of sorts.
The size of ballasts range from smaller than a deck of cards, to nearly four times that size, depending on manufacturer.
The set I installed today for a customer had the smallest harness I've ever seen yet, with the Hi/Lo switching integrated into the harness (no additional lumps of plastic in the harness), and the smallest slim ballasts I've seen yet.
All the best,
Shane
#60
ps: on coming cagers are the worst when it comes to dazzling oncoming motorists of all kinds.
I typically bite the bullet and turn my brights of my Slim. Even though I can barely see.
