HID install. WOW!
Old 10-24-2014, 02:47 PM
nikonf8's Avatar
nikonf8
nikonf8 is offline
Default Head light
I installed a truck phase 7 headlight excellent lighting it's coins eroded daylight actually I believe 5000 K is daylight and the truck I think is 6000 if you get one you will not regret it I also installed 5000 k passing lamp bulbs another great addition
  #72
Old 10-24-2014, 06:29 PM
Warp Factor's Avatar
Warp Factor
Warp Factor is offline
Some of us are doing pretty good by just installing an 8-buck 100/80 headlight bulb from an ordinary auto parts store.
  #73
Old 10-24-2014, 06:52 PM
amkaos's Avatar
amkaos
amkaos is offline
How did you handle trim rings etc? Your bike is awesome btw.
  #74
Old 10-24-2014, 07:18 PM
Shanebo's Avatar
Shanebo
Shanebo is offline
That's definitely an improvement over stock for halogen bulbs. I used to do the same thing for quite a few years, until the charging system couldn't take it with additional auxiliary lighting and accessories.
One of the side benefits of HID's is that after the initial startup, the current draw is allegedly much less than anything close in halogen light output. 35 watts is what most of the ones I've dealt with are rated at, per light.
That leaves much more to work with for other electrical accessories--for those who desire heated clothing and other things.
All the best,
Shane
  #75
Old 10-24-2014, 07:26 PM
bullast's Avatar
bullast
bullast is offline
I would like to add a brighter headlight to my FXDB.
Can someone post a link to the options discussed?
Or should I search through this thread and quit being lazy?
  #76
Old 10-24-2014, 07:55 PM
Warp Factor
I'm not running multiple peter-heaters or anything, (kind of stuck in "old school"), so I haven't put a big challenge on my charging system yet.
  #77
Old 10-24-2014, 08:14 PM
nikonf8's Avatar
nikonf8
nikonf8 is offline
Default Head light
It may be an improvement from the original bulbs but I am sure it will not match the truck light not only is it bright you can see the shoulder of the road you will not really know unless you actually have been on a ride with the truck light
  #78
Old 10-24-2014, 08:23 PM
Warp Factor
Maybe so. You've tried the 80/100 bulb?
  #79
Old 10-24-2014, 09:24 PM
Shanebo's Avatar
Shanebo
Shanebo is offline
He said "peter-heater"... heh, heh...
  #80
Old 10-25-2014, 08:32 AM
24v's Avatar
24v
24v is offline
I would be more concerned about damaging the headlight wiring with such a current draw. It is not uncommon to see this happen with higher wattage bulbs. Be cautious. If you want to run that bulb safely, I would wire a relay in with thicker gauge wiring.
pearldrums2
10-01-2014 02:29 PM
bigblock59
01-04-2014 11:04 PM
ggerline
07-22-2013 05:15 PM
Prodaytrader
03-13-2010 08:20 AM
Garemlin
07-31-2008 01:53 PM
Quick Reply: HID install. WOW!
