Rocker C front turn signal relocation wiring
#41
#42
Im going to try first to follow the channel and see if I can figure out the wire for the light of the stock license light… I don't want to remove the fender for just one wire…plus Im going to leave the light that is on the fender… the Kury license plate came with a metal chrome plate to cover part of the old fender setup and the stock fender light reflects on it…so it is OK.
I don't want to remove or change the fender for now… just hookup the LEDs on the license plate…and now will be a good time to do it…I will have to remove the seat to install the Load equalizer for the front LED turn signal some time next week, when I get the new lights…. I just want to remove the seat one time.
thank you all for all the help and ideas...
#43
#44
#45
There's a plug for the lights under the seat. 12 pin, I believe. The wires under the fender run through a plastic channel to keep them away from the tire. The fender is easy to remove. 4 bolts and the elec. connector. There's 3 seperate groups of wires in the channel. I'd have to look at mine again, but I'm sure it's left, right, and license. With the fender off, it's easy to pull the wires out of the channel.
I will need the wire wires that go to pin #12 and #6 maybe I can solder the license plate wires to it… or just like you suggested pull the wires out and re-route this channel to the side mount…
#46
#48
Update… I got the new LEDs, lenses….and the WRONG Load Equalizer, so...
I'm going to sell the Custom Dynamics (Slim Line CustomDynamics® Signal Stabilizer (Load Equalizer).. I made the mistake and ordered the wrong part. I will put it on the classified part of the forum $60 shipped and seller pays Paypal fee…
stagolee
03-16-2009 05:25 PM
