Turn signal/Brake light switch
Old 05-23-2014, 04:30 PM
Bluraven's Avatar
Bluraven
Bluraven is offline
Default Turn signal/Brake light switch
My 09 Heritage has the LED turn signals and brake lights. I just figured out that the rear turn signals illuminate when I apply the brakes.
I'm wondering if there is a controller some place on the bike that allows the turn signals to work as brake lights.
I've looked but can't find anything related.
Is there a way to set this up without a controller or is there a controller hidden somewhere?
Old 05-23-2014, 06:29 PM
Gman in NC's Avatar
Gman in NC
Gman in NC is offline
Should be plugged in somewhere under the seat. I don't use one but have friends that do.
Old 05-23-2014, 06:32 PM
jmn1960's Avatar
jmn1960
jmn1960 is offline
u can pull the 1156 bulbs and then pull the single wire pigtails ,, go buy two wire pigtais and some 1157 bulbs and hard wire into the brake and running light ,, thats what i did on my 2005 ultra ,, works like a champ
Old 05-23-2014, 07:26 PM
rbeamj's Avatar
rbeamj
rbeamj is offline
If yours is currently working as both brake and turn signals then yes there is an add on controller. It will most likely be under the seat near the rear on the right side if facing forward. That connector there is where the lights plug into
Old 05-23-2014, 07:38 PM
Bone Doc's Avatar
Bone Doc
Bone Doc is offline
Received 10,863 Likes on 4,113 Posts
If your rear LED turn signals are HD and they were wired per their instructions, they should function as running lights in addition to your brake light and turn signals. They are meant to function this way. There is no separate controller. It is wired into the lights themselves. If I recall correctly, they don't mention this in the big or the small print. It eliminates the need for HD's separate harness: http://www.harley-davidson.com/store...conversion-kit which saves you about $70.
To set it up without this function, you would have to alter the wiring. The wiring diagram is part of the instructions for the LED turn signals: http://www.harley-davidson.com/en_US...ts/-J04805.pdf
Now, if your turn signals are not running lights as well, there is either a control module or they were hard wired. If they are functioning as you would like, what is the difference if there is a control module or not? If you don't want them to function as brake lights... why? If you want to look for a module, I would first look where Gman and rbeamj noted; under the seat.
She has LED turn signals. There are no 1156 bulbs.
Old 05-23-2014, 08:13 PM
jmn1960's Avatar
jmn1960
jmn1960 is offline
oops
sorry missed that part
Old 05-23-2014, 09:16 PM
Bluraven's Avatar
Bluraven
Bluraven is offline
Bone Doc is probably correct.
The "red" turn signals are also running lights.
What got me wondering was I saw a controller that allowed the rear lights to pulsate prior to going solid, but you could also configure them to not pulsate.
I was just wondering if I had such a controller, but apparently not.
Thanks,
Old 05-23-2014, 09:46 PM
Bone Doc's Avatar
Bone Doc
Bone Doc is offline
Thanks,
Bluraven,
I use this brake light modulator. It is plug-n-play and installs in minutes. There are several patterns to choose from.
http://www.customdynamics.com/motorc...ht_flasher.htm
Even though your turn signals function with the brake lights, the modulator only flashes the brake light. It is compatible with LEDs.
Old 05-23-2014, 10:07 PM
Bluraven's Avatar
Bluraven
Bluraven is offline
Thanks Bone Doc.
I doubt I'll upgrade to it, I was only wondering if I had a modulator.
CDFXD
11-19-2016 02:11 PM
tmultra
03-16-2016 03:17 AM
joebedford
Electrical/Lighting/Alarm
08-01-2015 06:41 PM
jsims002
05-15-2013 05:11 PM
Harmberg
04-20-2010 10:41 AM
Quick Reply: Turn signal/Brake light switch
