Largest Rim and Tire Combo on 02' FXSTI
Guys,
What is the largest rear rim size that I can go on a stock 02' FXSTI? The fender is about 7.25" wide. I believe there is a 3.0" on there now. Is it possible to upgrade to a 4.5" and run say a 160mm or 180mm tire without modifying anything else such as the swingarm, fender, pulley, belt, etc.?
Thanks....
Thanks....
Thanks Sgt_Jim... there has to be others that know or can suggest what size rim to go with in the rear and tire size without any mods.. anyone!?!?
I'm running a 150 Avon Cobra on a 16" solid disk rim on my 02 FXST and there's a pubic hairs amount of room in there. I'm not rubbing or bottoming out and never have but without modifying the fender or swingarm I can't imagine going any wider.
160/4.5 is about max without going to wider fender, and will require minor mods...and that is pushing it depending on tire brand. Several people have put a 200 on with the stock swingarm and factory parts, but you have cut the frame horns.
The rear wheel set up was already done when I bought the bike back in 2011. I don't have any other tech data for you unfortunately.
