Where could this oil leak be coming from????
Old 06-12-2014, 02:34 PM
mclldavidson's Avatar
mclldavidson
mclldavidson is offline
Default Where could this oil leak be coming from????
I have an 03 fatboy and have never had a leak. I changed my engine oil yesterday and when I woke up this morning I had a huge oil leak. It appears to be running down from back behind where the oil sits. I dont know or see what could have happened.
Old 06-12-2014, 03:30 PM
hvacgaspiping's Avatar
hvacgaspiping
hvacgaspiping is offline
Received 16,189 Likes on 8,355 Posts
Check your breather filter located just upward and a little behind of the oil plug in the oil tank. It`s attached to a hose coming from the crankcase. Chances are it`s plugged; replace it.
Old 06-12-2014, 07:11 PM
mclldavidson
Thanks, do I need to remove the oil tank?
Old 06-12-2014, 07:28 PM
chester1957's Avatar
chester1957
chester1957 is offline
Also check the rubber elbow that attaches the oil drain down tube to the tank.
Old 06-13-2014, 02:04 PM
mclldavidson
My tank completely leaked out
Old 06-13-2014, 04:03 PM
Jim Kraft's Avatar
Jim Kraft
Jim Kraft is offline
Ya didn't pull the drain hose off of the tank when you were changing oil did you? Might want to check to see if that is where it is leaking.
Old 06-13-2014, 04:12 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,512 Likes on 3,770 Posts
Old 06-13-2014, 05:12 PM
mclldavidson
No I just put it on my jack like normal and removed the plug, I will check but I cant really tell. There is no room and way for me to see behind there.
Old 06-13-2014, 05:37 PM
Jackie Paper
If you look up from the bottom just fwd or behind the brace that comes across that the drain fitting is hooked to and you can see the hose going on up to bottom of tank.
Old 06-14-2014, 05:31 PM
HDnoob's Avatar
HDnoob
HDnoob is offline
Mine leaks a little bit from the rubber 90 degree fitting on the back of the tank for the drain hose. Of course last time I changed my oil I completely forgot about it. I also have an 03 softail.
gabrown44
05-04-2010 07:45 AM
sousap
Ironhead
07-20-2009 05:11 PM
tealdreams
Oil Archive (no new posts)
02-16-2009 06:08 PM
icedearth
08-08-2007 03:06 PM
WARG
08-15-2006 12:27 AM
Quick Reply: Where could this oil leak be coming from????
