Help with GotSaggyBags Install
I have the GotSaggyBags inserts, but I do not have the ability to cut wood into the shape of the top of the saddlebags. I think it is unreasonable to have this requirement without it being mentioned before purchase, but that is a different story altogether. If I return them I will be charge a 10% stocking fee and I am unwilling to pay my local dealer's service rate to have them installed. (not sure if they will be able to install them either because they don't have the top required piece of wood and do not know if they will make one - and if they do how much they will charge me.)
Does anyone still have the wood pieces you used when installing theirs that you would be willing to ship to me if I pay the shipping costs? If not, I am going to have to send them back and eat the 10%, but I would rather not. I will try using bricks instead of wood to see if that works since I have a bunch of bricks lying around, but I would like a back up plan if in case it doesn't. The installation instructions seem to require the wood to be shaped like the bag and not just squared off...
Follow up question - I read an article that says that HD recently addressed the issue with these bags by reinforcing them. I have a 2014 so if they did, my bags should be the newer reinforced type. Can anyone confirm this?
When I installed mine I used some weights and dumb bells I had laying around. Put the bricks around the edge of the insert and one or two on the in side let it sit for the period of time called for ( I think 24 hrs.) then just reinstall your bags. They say wood so that the weight is distributed equally but bricks will do the trick.
I've put the lid on one of my saddlebags so far. Used too thick stack of towels and ended up with a slight bulge in the top. It looks ok since it is leather, but not quite what I was expecting.
Someone on another thread mentioned drilling holes in another wood form for the studs, then don't need the towels and can clamp it. I may try that on my second bag.
I have noticed that the flap on forward side of the lid has a tendency to flair out occasionally on the corner nearest the bike.
On another note, when I use my large T-bag, the side without the lid insert is easier to access. YMMV.
