front wheel question
There are a whole bunch of issues you need to deal with.. Spacing will be different for sure since the 91 uses timken bearings with a separate seal and the TC wide glide uses a sealed bearing.. Ar you sure the WG uses a 1 inch bearing?? I'm pretty sure the 00 and 01s were still 3/4 inch.. Anyway if it has 3/4 or 1 inch sealed bearings you'll need to come up with different spacers.. I think that the widths will be close, you'll have to bore the center out of the disk rotor or use a non brembo twincam rotor.. I've not done the particular setup but a machinist should have no problem cranking out spacers sleeve the axle to 1 inch and set the disc rotor spacing correct..
i guess i should have specified that its not a stock harley wheel. its an ultima king spoke wheel 21" x 3.5" http://www.ebay.com/itm/Ultima-King-...4f159f&vxp=mtr
and i would use these http://www.ebay.com/itm/like/380692562854?lpid=82
Well,
You still have to re-space everthing.. The axle for an 05 is a 43346-83B which means it is 3/4
http://www.granitestateharleystore.c...c%7eLACED%5cGP
So I would guess you don't need the spacers that you listed as they are 3/4 to 1 adapters and a 00 to 06 uses a 3/4 inch axle...
