25000 mile service
HERE YOUR ARE ARROWSLINGER, DID NOT TAKE ME LONG.
Harley-Davidson Scheduled Maintenance: 25,000 Miles
Actual Mileage: Date:
Item Procedure Complete
Engine oil and filter Replace
Oil lines and brake system Inspect for leaks
Air cleaner Inspect, service as required
Tires Check pressure, inspect tread
Clutch Check adjustment
Drive belt and sprockets Inspect, adjust belt
Throttle, brake, clutch controls Check, adjust, and lubricate
Jiffy stand Inspect and lubricate
Fuel lines and fittings Inspect for leaks
Fuel filter Replace
Brake fluid Check levels and condition
Brake pads and discs Inspect for wear
Spark plugs Inspect
Electrical equipment and switches Check operation
Steering head bearings Adjust
Air suspension Check pressure, operation, and leakage
Cruise control Inspect disengage switch and components
Fuel door and saddlebags Lubricate hinges and latches
Battery Check battery and clean connections
Road test Verify component and system functions
Here is a checklist to do it yourself. No reason to spend extra money on service.
__________________
Fuel filter Replace
Spark plugs Inspect
__________________
