new breakout oil change...
Old 07-31-2014, 10:05 AM
JiXeR's Avatar
JiXeR
JiXeR is offline
Default new breakout oil change...
so, today will be my first real oil change (just hit my 6k mark). so, any suggestions on what i will need to get? i'm planning on royal purple oil (although i don't know the viscosity to get) but what other tools will i need? any other tips you could give me? i've never done my own oil changes before, but everyone's got to start somewhere.
Old 07-31-2014, 10:29 AM
jgos929's Avatar
jgos929
jgos929 is offline
I use Royal Purple on my bikes its good stuff. You need 20w-50
Old 07-31-2014, 10:31 AM
tbonetony06's Avatar
tbonetony06
tbonetony06 is offline
I use the scavenger, you can Google it. I do 20/50 in the engine and primary and 75/90 in the tranny. I only use Amsoil. I also change the rubber O-rings on the drain plugs every time I change my oil. A new filter, obviously.
Old 07-31-2014, 12:38 PM
JiXeR's Avatar
JiXeR
JiXeR is offline
thank you, that's good advice. i'm going to stop by harley on the way home and grab a filter, oring, and filter wrench. someone told me that the bike needs to be standing straight when you change the oil. so, i might have to grab a jack too.
Old 07-31-2014, 12:44 PM
mkenkel's Avatar
mkenkel
mkenkel is offline
If your planning on doing the tranny it is much easier with a jack. the oil bag and primary are simple enough on the ground.
Old 07-31-2014, 02:54 PM
UT-rckr's Avatar
UT-rckr
UT-rckr is offline
They tell you to stand it straight because the drain for the oil bag is on the right side, and if you drain it while on the kick stand you will leave some oil in there. You will be just fine to drain it while on the kick stand, and then once oil stops dripping, just straddle it and get it up straight for a few mins. Then lean it back on the kick stand and button her back up.
Old 07-31-2014, 03:05 PM
JiXeR's Avatar
JiXeR
JiXeR is offline
aahhhh, that makes sense. thanks!
Old 07-31-2014, 04:09 PM
HD and VETTE's Avatar
HD and VETTE
HD and VETTE is offline
All the above good info and I use tin foil to make a drain sheet for your oil filter.
Tucks under filter good and I always punch a whole in the bottom of the oil filter to let it drain in one spot before taking oil filter off otherwise its all over the place.
Dont forget to check oil level after on the leaning on the stand.
BackinBlackfxdb
08-04-2010 08:16 PM
Wrongturn
08-16-2009 08:06 PM
Frankie-FLHXI
03-09-2009 12:03 PM
anubisss
07-11-2007 09:00 PM
Aroberts
Oil Archive (no new posts)
14
05-15-2007 11:46 AM
Quick Reply: new breakout oil change...
