DTC Code Help 2012 Deluxe
While out on a ride the other day my battery light came on (no check engine light). When I got back home the bike would not start right after shutting down, but I could get it to start after about .5hr. I haven't ridden since, but I have started the bike without issue after being on a trickle charger.
I checked the DTC codes using the odometer and it turns out the bike is throwing a few codes:
ECM y: P0562, P01632, and Pn 001118-01
BCM y: b2161, b2173 and Pn 69991-11A
SPDO y: b1210 and Pn 67439-11
Can any break down what these codes mean?
Thanks
Thanks
Here you go. The search function is your friend.
https://www.hdforums.com/forum/ignit...tic-codes.html
This morning, my 2012 Deluxe is showing BCM Y with codes:
b2136
b2141
b2146
u0142
Would anyone have the meaning for those codes?
Thanks
*edit: I think I figured out b2136 but would still be nice to have clarification. I cleared the codes but b2136 won't go away. I see that the headlight is out. I believe b2136 to be the headlight.
Haven't had a chance yet to run the bike to see if the others come back or not. Still would be nice to know what they are.
*edit: Ok, after much digging...found this site: http://www.scribd.com/doc/229588490/...BSE-Supplement Page 167 starts the codes listing.
In that I found that b2141 is from left front turn signal being out. b2136 is from the low beam being out (as I figured), b2146 is from right front turn signal being out and u0142 is lost communication from LHCM. Hope these codes make a sticky for others. Maybe someone can figure out how to get the list into the body of this thread.
steelhead
03-11-2012 05:54 PM
