Can't reach rear brake pedal due to air cleaner
I have an 05 FXSTi.
I'm suprised there isn't more on this, but my rear brake pedal is a pain to reach. I don't need one that is longer, I need one that is 1.5-2" more to the right.
I looked at a few sites and they all just sell longer pedals. I think the Kury said it moved half and inch to the right too but thats not enough.
What do you all do about this?
I have the same problem on our '12 FLSTC. I have the inverted Arlen Ness A/C and I'm in the process of bending the rear brake pedal arm out, making the factory "Z" bend angle longer to offset the pedal farther out so I can reach it. It is a pain even with the stock A/C. I will post some pics when I'm done. I might have to have the pedal assy. re-chromed as I will be heating the pedal assy. to bend it without causing stress fractures when I use my hydraulic press to bend it.
You can also try a low profile Air Cleaner like our Outlaw 587.
They provide plenty of leg room to where you do not feel cramped.
Click HERE to see lots of different options.
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
www.DKCustom.com
662-252-8828 Voice
EASIER FIX, move the entire control mount OUT. i have the hyper R charger as well, i bought i kit to extend the pedals out. i only used 1/2 the kit as if you install both sides, it stretches the jiffy stand spring and it wont stay up tight. i know this as i had to replace the spring. anyway if you want the other 1/2 which is all you need shoot me a message and we can work something out.
