13" Rotors on a Fattie / Softail
Has anyone upgraded to 13" rotors on a Softail? Hill County Cycles & RC Components make brackets adapting the HD-Brembo calipers for the Touring range but can those same brackets be used (with the HD Brembo calipers) on a Softail? If not, are there any other caliper relocation brackets that are readily available for Softails to move to a 13" rotor.
I've already moved to the HD-Brembo Touring Calipers & an 11.8" full floating rotor. I still feel the setup is a wee bit short on real confident stops from speed despite ABS.
Look forward to some insights.
Gaurav
Gaurav
I have been looking very hard for 13" caliper bracket with no success. I dont think the bagger 13" caliper bracket will fit. It would be great if some one could measure a softail and bagger to verify.
You can use a caliper designed for a 13" rotor. $380.
http://www.ebay.com/itm/NEW-PM-CHROM...67a71a&vxp=mtr
Have found a bracket that may work...
http://www.bikerparts-superstore.com...0-up-big-twins
Their tech have confirmed it would work with touring calipers on a softail. Do take a look and share your thoughts. Would be helpful as I'm on the other side of the world & shipping parts is pretty painful.
Gaurav
Gaurav
A discrepancy with the Application models listed as FLST is not listed. However, FLST is listed in the tech notes. But it says to use "#23-1569 caliper bracket for FLST model". The 23-1569 is the right side bracket.
Secondly, when they say to use a touring caliper, are they referring to the newer brembo which uses an 11.8" rotor or the older style which uses an 11.5 rotor?
Try contacting manufacturer, v-twin mfg to confirm.
APPLICATION:
Fits:
FLT 2000-UP
FXST 2000-UP
FXDWG 2000-UP
Details:
Front brake caliper left side bracket is billet machined aluminum, and clear anodized. Bracket relocates the caliper to fit a 13" brake disc.
Use this caliper bracket with a stock caliper for a 13" stainless steel brake disc.
UOM: EA
TECH NOTES:
Suggested to use with #23-1567 front caliper bracket on FXST and FXD models
Suggested to use with #23-1568 front caliper bracket for FXST and FXDWG models
Suggested to use with #23-1569 caliper bracket for FLST model.
APPLICATION:
Fits:
FLT 2000-UP
FXST 2000-UP
FXDWG 2000-UP
Details:
UOM: EA
TECH NOTES:
scottylonebull
01-28-2021 06:26 AM
misfitJason
03-20-2019 12:46 AM
