Help! - swapped bars, left controls not working
Clutch side controls (Trip, Horn, Lights etc etc) are no longer working. Everything was fine right after the swap, except I had a loose connection with the right side turn signal which was causing it to shut off at full left/right turning. Fixed that, but the left controls are now dead. Followed wires from housing, under tank, to battery area and can see nothing. Removed controls to see if maybe the wires were pinched, looks fine, and did not work when loose; connection looks good.
Anything you can think of that I may be missing?
I can't pull codes because I can't use the trip button, and I don't have a reader. Going to check fuses now, but I don't think the left controls have their own fuse... I'm gonna go find out
thanks
*** sorry, it's a 2012 Softail Slim
thanks
Did you lengthen the wires? If so, what kit did you use? Need more information.
I had the same issue. Used the Burly kit and the plug on their extension harness had a bad connector in it. Try to unplug and plug the connector under the tank. If nothing works, the switch assembly isn't getting power.
Soooo... removed extender kit, no joy with left controls still. A nice new addition - speedo is throwing V Inner code during start up and it's had a few non starts. This is getting beyond me now, hopefully I can limp to the stealer in the next few days.
Seen a few V Inner threads, none seem to have a decisive answer... lots of could be stuff
Well, let's start with the basics. Before you touched it they worked. The only thing that could be wrong would be a bad board in the control, a bad bcm, or a wiring issue. Since you touched the wiring while doing this mod, that is a great place to start. Pull all the wires back through the bars and check them. Did you buy plug and play extensions, or did you splice new ones on? If they are plug and play then start checking the pins in all of the connectors. There are 2 wires specifically that go to and from the bcm. If either of these was just missing making contact you would have these issues.
The speedo dropping out here and there is troublesome. It stays lit, but the tach drops to 0 for a few seconds then comes back
Turn signals needed to be removed from connector, they're working fine now, everything else fit through the bars as is. I was just wondering about codes due to the new V Inner code and speedo tach drop out.
