Outer Primary Cover Drain Plug 'spinning'
Hi all
I was changing oils in my 05 Softail and got to the primary cover. Drain plug just keeps spinning around. Can't tighten it, can't loosen it, funny thing is, it doesn't leak.
Have done some research and appears it has been an issue to some owners before.
Scavenged oil with a hand vacuum pump. Harley typically suggested a new cover.
My questions are;
Can I get the drain plug out without taking the cover off and;
What fixes are there, if any? Keep in mind, being in Australia we don't have access to all the fix it stuff you guys have in the States.
Thanks in advance for your help.
Cheers
Darren
My questions are;
Cheers
Darren
Doubled checked after a long ride today & yesterday, no leaks what so ever!
Damm thing spins right and left without tightening or loosening, has me dumbfounded but I leave it and check for leaks.
Thanks for your reply.
Well the threads in the primary have been stripped out. It's likely going to be a primary cover replacement to fix it. Sorry. I don't think Harley makes a self-tapping drain plug like you can get for stripped automobile oil pans. You can check and see if they do, but I've not heard of one.
Been There Done That! Easy fix. Remove the primary cover, drill out the plug and re-tap the hole. Use and short hex head bolt for the plug. When inserting the plug add a little thread sealer to prevent leaks. If you don't feel confident doing this, take the primary cover to your local machine shop.
