Do I need a different kind of steering stem?
2008 Softail Heritage
Took the original triple trees and forks out and am replacing it with a different set of triple trees. The stem on the original lower tree was a press fit plus a snap ring at the bottom. It the new one it slides in easily and snap ring should rest. on a collar(see the pic of the opening). But the diameter of the ring is way bigger. If I just put the ring outside the whole thing rocks a lot and also the stem id shorter by half an inch. Do I need a different type of stem or a different snap ring?
up side down
You have the bottom triple tree up side down on the pictures with them on the forks. I do not know about your steering stem, see the manufacturer on that. One of the two ends of your triple trees should be connected one way or another to the the steering stem so it does not move.
Is this what you are referring to that I need?
http://www.ebay.com/itm/DNA-CHROME-N...item540ec8483b
