battery removal
Old 09-18-2014, 07:10 AM
apetterez's Avatar
apetterez
apetterez is offline
Default battery removal
how do I remove my battery from under the seat on my 2012 Sportster
Old 09-18-2014, 08:17 AM
elfnyc's Avatar
elfnyc
elfnyc is offline
Old 09-18-2014, 10:02 AM
Greeley's Avatar
Greeley
Greeley is offline
Its a huge PITA the first time you do it, after a couple times things will get easier.
Old 09-18-2014, 11:14 AM
franktko's Avatar
franktko
franktko is offline
Originally Posted by elfnyc
Delboy's Garage, Harley Sportster Battery Replacement . - YouTube
I was really struggling first time I removed the battery, following owner's manual about removing negative first and that failure do to so could RESULT IN DEATH (you realized that after reading 10 pages of the manual, HD already warned you about DEATH for at least 45 times). Then I stumbled onto Delboy's video and it was just a piece of cake after that!
Old 09-19-2014, 12:02 PM
alcotune's Avatar
alcotune
alcotune is offline
Just watched the video. I find that way hard unless the newer Sportsters have a longer negative cable.
I disconnect the positive then take off the negative cable from the top of the engine (block? - see pic for area) then the battery can be pulled out with the cable attached.
Old 09-19-2014, 03:16 PM
Roni's Avatar
Roni
Roni is offline
Don't forget to PULL THE MAIN FUSE first. There's no sense in putting your scoot's electrical system at risk.
Old 09-19-2014, 04:56 PM
PumpinIron's Avatar
PumpinIron
PumpinIron is offline
Yes, every time I read my service manual that makes me laugh. They are warning you about death every chance they get. It's quite funny because most of it is common sense.
Old 09-20-2014, 12:40 AM
Eisentreiber's Avatar
Eisentreiber
Eisentreiber is offline
... which can be in short supply for a few folks. MoCo just doesn't want to get sued. Life is dangerous and invariably will result in death
moexha
Electrical/Lighting/Alarm
09-24-2020 02:05 PM
brandss
2014-2023 Touring Models
17
05-18-2017 07:24 AM
nasumi2002
11-04-2010 10:10 AM
HRLY07
05-01-2008 09:58 PM
anubisss
03-05-2007 11:51 PM
Quick Reply: battery removal
