Went With Synthetic Oils
Well, I finally did it after reading many/numerous/opinions about Synthetic Oils in the Primary and Main. I had been using Harley Formula Plus and HD 20W-50W oils. I decided to change out my Primary and Main to Mobile 1 Synthetic Oils in Both the Primary and Main. I put in Mobile 1 15W-50 and I used Mobile 1 Synthetic Gear Lube LS, 75W-90 in the Primary.
My results after a 60 mile ride is that I'am very pleased so far with this change. The Shifting Seem to be smoother. As Far as the Engine, I can't tell what difference, other than the Synthetic Oil should preserve the increased lifetime of my engine. I Change Oils & Filter at 3500.0 miles, on my 07 1200L.
Very Pleased!
Racer
Very Pleased!
Racer
For the 15w-50, try a Super Walmart if you have one in the area, they tend to have it more-so than the regular stores around here. It's usually stocked in a 5 quart jug (packaged exclusively for Walmart) for $23 - $25, depending on your location.
Racer
That's exactly what I'm running in mine. Was already using the Mobil 1 in the main but it was the kind made for "motorcycles". Apparently the automotive blend is better protection & the other is not required in our sporties because it's not shared. Anyway I guess I'm happy with it so far - top end might be quieter now I don't know. Can't really tell if there's a performance difference or not. Still runs right at 200 degrees when it's hot out so whatever - definitely didn't hurt anything.
