Auxiliary lights with Daymaker LED?
led alllll around !
the headlight is the daymaker
the blinkers are custom dynamics , dynamic rings ..
the white goes off and flashs yellow with turn signal
then go back to white when the turn signal is turned off
the rear are also led custom dynamic rear / red led
the front blinker led lights give off loooooads of light as u can see almost as bright or if not the same , at night if i cover them you can see the differ ...
they help cagers see you better as well
im sure they will be brighter then mine when u use the clear lens covers with them - but i have smoked lens on mine which cuts down on the light more im guessing
i have no complaints what so ever with them ... in fact id have it no other way now having them ..
I'm not sure what I want to do yet.. get the daymaker, or just get reg aux lights vs led aux lights.
