How loud are my Cobra Slip ons?
I recently installed 3" Cobra slip-ons on my 2011 1200C. Not ever having put aftermarket exhausts on a bike previously, I was surprised by how loud they are. If I was a bit younger and didn't care, i'd be happy with them.
Basically, I've seen comments that the Cobras aren't loud and comments that they are loud. What I am trying to figure is what is the perceived loudness of these slip-ons to passersby? (I know, I could ask, but that is kinda hard to do at the time.) I know they are going to sound loudest to me as I am sitting on top of them and the front pipe exhaust is right next to my ear.
I want louder than stock, but not obnoxious I like my neighbors. I am just wondering if they are too loud. I have ordered the quiet baffles for them to see if that reduces the volume a bit.
Opinions? Recommendations?
I will say that I have the Cobra PowerPro HP 2 into 1. My criteria was that I wanted a deep rumbling sound that wasn't so loud it was obnoxious. And luckily that is exactly what I got, in my taste and hearing. Actually I am kind of hoping that it will get just a little bit louder as it breaks in. If it doesn't I will still be extremely happy with them. But if it does than that is good also.
Thanks crawrj. I know the bottom-line is that loudness is subjective and the final decision is mine. Unless I get pulled over!
Well, if I don't figure sit out sooner, I'll have answer on Sunday. I am going on a charity ride to Atlantic City and I should be able to get some opinions from fellow riders. Might even stumble on someone who has them installed on a similar sporty. I should have the "quiet" baffles in by that time.
I'm probably over concerned about what others think.
I know that my neighbor's kid has ticked me off more than once with his race quad. First I'd have to listen to him rev it up as he worked on it. (Our back yards are connected.) Then he would take off around the neighborhood on a test ride. That thing was too loud the next block over!
Anyhoo, thanks for your thoughts.
For example, using the Android "Sound Meter" app as an example, certain phones (Galaxy S3) cannot detect anything louder than 81 decibels. If you get an 81 decibel reading, all you really know is that the sound pressure level is at least 81 decibels, but it could be higher by any amount. So an 82 decibel sound will register as "81 decibels" on the S3, but so would a 120 decibel sound.
Basically, while the apps do well enough within the normal ranges of human voice (between about 30 and 70 decibels), they aren't reliable at high volumes because the phone's mic isn't set up to handle that.
Also, remember that phone mics are set up to respond best to human vocal frequencies and often have poor response to sounds in very low or very high frequencies. So there's a good chance that the mic isn't able to properly pick up a motorcycle's exhaust.
I don't mean to say he shouldn't try using one of these apps, but he should be aware of its limitations, especially if he gets a reading above about 80 decibels, which could be correct, or could simply be the upper limit for his device with the real reading being a little (or a lot) higher.
Well, if the baffles don't work out, someone recommended installing some lollipops. It either that or I'll just get the screaming' eagle set. Also, I didn't realize I was removing the catalytic converter when I removed the stock mufflers. oops!
If you have removeable baffles , there's always a way to tone them down.
If the mufflers have a 3" straight muffler body , there are probably at least 20 different sets that you could look at at jpcycles.
If you can look through them end to end , they will be fairly loud.
The DK baffle things might be a quick way to tone them down , maybe even use the original baffle mount bolt hole to mount it.
Of course if you think they are too loud , then they are .....
Mick
Mick
Yep, you can see straight down. Nothing in the way. I have a set of quiet baffles on order.
Oddly enough, I had my daughter stand in my neighbors drive way about 25 feet away as I drove by. She said not that loud and she couldn't hater me the next street over due to another neighbor mowing the yard.
I'm going on a group ride Sunday so I'll get some opinions.
