Side Plate/Battery Cover Falls Off Constantly
Recently purchased a brand new 48 and the side plate or battery cover keeps un hooking from the two top clips. Everytime I get up to 30 MPH or hit a bump with no fail it falls open! Went in for 1K service and told them. My service report said the 02 sensor was pushing against it so they adjusted it! ( HA )
2 days later hit a small hole and it completely fell off and hit the car behind me...)
Went back to service and asked for a replacement and to put new clips on, they said its not covered under warranty, so no can do. This is a joke! I know 2 other 48 owners and they have the same problem! Part costs $115...!
Any advice..? bc this is a factory issue.
thanks all.
thanks all.
It's a common problem. It's quite sad that your dealer just said their hands are clean of the problem. Mine made adjustments and said if it keeps dropping down they would replace the clips even though it probably wouldn't help. They really care about customer service there. I put a bead of super glue along the point of the clip that the cover connecting piece has to pass over to unlatch.
Here is a topic that it was dicused previously and there are some other solutions. I posted pictures of what I did there.
https://www.hdforums.com/forum/sport...stening-2.html
Received 2,189 Likes
thanks all.
thanks all.
basically snitch
**** falls off bikes, somebody told me to get used to it, so far i lost my favorite riding gloves, then the garage door opener, which i luckily found, then my really nice earbuds, got caught in the drive belt and almost pulled my ipod nano with them, uh ...it's a bike...and you should do a pre-ride check anyhow, if it was loose then it needed to be fixed before you went for ride...it's not a car...if the right piece falls off you will get hurt
+1 - There's no need to attach the zip tie to the frame, just drop it into the hole. This way there's no need to cut the tie or need a new one when opening the cover.
