Need help/info i want to ride!!!!!
Old 10-14-2014, 10:34 AM
whitlow's Avatar
whitlow
whitlow is offline
Default Need help/info i want to ride!!!!!
So it's nice here today in southern Va and I'm off work so I went out to ride my 06 1200. It started up but cut off when I went to start it again nothing! It was dead! No lights in the speedometer I turned the key off and could hear noise from the speedometer that it. When I turned the key back on the noise stopped but nothing. Please HELP I want to ride today if I can!!!!
Old 10-14-2014, 11:52 AM
lo-rider's Avatar
lo-rider
lo-rider is offline
Did you read the troubleshooting section of your owners manual or service manual?
Old 10-14-2014, 03:38 PM
Iarecobra's Avatar
Iarecobra
Iarecobra is offline
Check your battery connections. Make sure they are tight....next look at your fuses.
Old 10-14-2014, 03:52 PM
kingxirol's Avatar
kingxirol
kingxirol is offline
Post
+1 on checking battery connections.
Most likely cause is your battery. How old is it? If you are lucky, it would be as simple as charging or replacing the battery and God forbid if you are at the deeper end of ****, it could be a bad stator or something even worse (I hope not).
Old 10-14-2014, 03:57 PM
kngpn's Avatar
kngpn
kngpn is offline
Received 5,116 Likes on 2,674 Posts
is your key in the ignition and not the fork lock?
Ok I admit it, I did that once..
Old 10-14-2014, 04:03 PM
kingxirol's Avatar
kingxirol
Post
This cracked me up. And no offence ... I am guilty of doing it once as well.
Old 10-14-2014, 04:07 PM
whitlow's Avatar
whitlow
whitlow is offline
Checked the battery connections, it started right up the first time. And the fuses are all OK.
Old 10-14-2014, 04:24 PM
DK Custom's Avatar
DK Custom
DK Custom is online now
Platinum Sponsor
Received 3,930 Likes on 2,288 Posts
Cool! Hope you're out riding!
When you get a chance, get some dielectric grease on those connections and keep em tight!
__________________
Kevin
DKCustomProducts.com
Call/Text: 662-252-8828
Old 10-15-2014, 03:02 AM
Iarecobra's Avatar
Iarecobra
I like to check my battery connections from time to time. They like to vibrate themselves loose.
Dheez
08-18-2017 01:00 PM
Holloway2146
Electrical/Lighting/Alarm
08-05-2017 12:32 AM
xsitenlife
08-01-2015 11:17 PM
el ricky
09-12-2012 02:09 PM
starbucksound
05-24-2007 11:48 PM
Quick Reply: Need help/info i want to ride!!!!!
