FI Sportster Motor Question(s)-48/72/883
A friend of mine was talking about the 48/72 Sportsters and the motors in them (1200). I chimed in asking that with the new FI motors, can you tune up the 883 to be comparable to the 1200 in the Sportster models. He and I are old school carb guy's and don't know anything about the FI motors/the how well the PC can tune them or how far you can take the computerized motors etc.
So we started looking at some engine specs and here is what I found on-line. Not sure if they are correct. ??
883:
Bore-3"
Stroke-3.81
Comp-9.01
H.P-53/48ftlbs torque
1200:
Bore-3.5"
Stroke- 3.81
Comp-10.1
H.P.-65/72ftlbs torque
Then the question(s) came up:
1. "Is there a difference in the cam profile/lobes/duration etc between the 883/1200 or just the heads/cylinders/pistons."
2. "Can the jugs (cylinders)/cam/heads/pistons be changed out to a 1200 series w/the FI motors and is it worth it."
3. "Or, can the 883 actually be tuned (pipes/tuners/air intake etc) with-in reason to the 1200's H.P/torque range without changing out the jugs, cam etc?"
We said we didn't know and would ask.
Reason this conversation took place is I was looking at the 48/72 on-line from the HD site and then the Iron caught my eye, but it has the 883.
So, we went to HD dealer looking at a few bikes and I looked at/sat on all three and liking them all.
Thanks for the help, hope this makes since,
Jim
883:
Bore-3"
Stroke-3.81
Comp-9.01
1200:
Bore-3.5"
Stroke- 3.81
Comp-10.1
Jim
Found some answers, so I thought I would post them in case any are looking into this.
1) Cams are identical.
2) Cylinders and Pistons are interchangeable, or you can do a bolt on 1250cc
NRHS - High Performance for your Harley Twin Cam, Evolution, Sportster or Buell!
A set of heads from a 1200 would be worth it as well.
3) No
Cylinders and pistons are interchangeable. 1200 heads will breathe better. You can tune the 883's horse power to match an un-tuned 1200, but that power will be at a higher rpm. The torque peak will be at a higher rpm. ( less torque at higher rpm = same horse power).
3) No
You have several options when increasing the size of an 883:
- use the H-D conversion kit, which comes with all the bone stock 1200 parts, is expensive and simply gives you a factory 1200,
- use the SE 1200 kit, which uses your 883 heads and comes with SE tuner, cams and higher CR pistons,
- use a Hammer or NRHS 1250 kit (S&S makes a 1200 kit), which comes with higher CR pistons. Hammer and NRHS both offer a wide range of other tuning options.
Thank you.
I have looked up a few Nightsters and most are wanting $7500.00-$8500.00.
Might as well get a new Iron with warranty and do a 1200 kit later on after I get use to it/first bike.
Still researching a few things, still torn between the 48/72 but I like the 3.3 gal tank on the Iron and w/some mods the bike (Iron) does look sweet.
I also like the red spooked rim upgrade for the street bob. I like the spooked rims you have in the pic and the bars-good looking bikes.
Thanks again for the pics and info guy's, bookmarked it.
Jim
Jim
