Gear fluids, reading about ATF in the gear case?
Old 10-22-2014, 10:51 AM
DavidStiebel's Avatar
DavidStiebel
DavidStiebel is offline
Question Gear fluids, reading about ATF in the gear case?
Hey all,
Ive read that many larger bikes are running regular or treated ATF in the transmissions, seems kind of off beat to me but I'm in the sticks so what fluid do you use / recommend for the 1200 transmission?
883 can chime in too.
Cheers,
Old 10-22-2014, 12:30 PM
jmn1960's Avatar
jmn1960
jmn1960 is offline
i run atf in the primary ,, gear oil in transmission
Old 10-22-2014, 04:37 PM
Scuba10jdl's Avatar
Scuba10jdl
Scuba10jdl is offline
Old 10-23-2014, 07:12 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
The big twins have three oil reservoirs, our Sporties have only two. ATF may be used by some (I wouldn't use it) in a big twin primary, but I use transmission oil in my - er - transmissions, big twin, Buell and Sporty.
Old 10-23-2014, 07:08 PM
jag1886's Avatar
jag1886
jag1886 is offline
I used aft in the primary on my RK but not in the trans. I'd just use a syn oil of the right specs in a Sporty not atf .
Old 10-24-2014, 02:15 AM
DavidStiebel
That's what I thought, HD is very explicit and I try to stick with what they say, when I read the forum below I wondered.
http://www.*****************/forums/...imary-oil.html
Old 10-24-2014, 03:04 AM
gusotto's Avatar
gusotto
gusotto is offline
Don't get confused with some of the input with ATF here. Those that run ATF are riding different bikes (Big Twins with three holes), not a Sportster (two holes.)
A Sportster only has engine oil and oil for the tranny/primary (shared oil.)
If you're in the sticks as you say, just buy an extra bottle or two for changing.
Myself, I still run Sport-Trans oil in my Sportster. I got a deal from a dealer and now have 36 qts. on hand.
A bit much but it only cost me $28.
Harley now recommends their Formula+ as a replacement for Sport-Trans.
Old 10-24-2014, 08:09 AM
Scuba10jdl's Avatar
Scuba10jdl
ATF is really not that big of a deal in the Sporty trans. Automatics have epicyclic gears and chains and clutches. Not that different from a Sportster primary/trans. I'd have no problem running it. I just think there are better options.
The main reason to run gear oil or HD's recommend fluid is that the primary purpose of the fluid is as a gear oil for the transmission. It's secondary purpose is to cool the clutch and lube the primary chain. It doesn't take a very fancy oil to do that.
The challenge is protecting the gears as they mesh, hence why I run the gear oil. There is a lot of contact stress at the faces of the gear teeth, and they need all the help they can get.
zolone
05-08-2017 12:56 PM
shaker
Oil Archive (no new posts)
02-04-2013 07:09 AM
miacycles
07-07-2011 08:01 AM
RAL
10-19-2010 03:05 AM
skyking
06-01-2005 07:39 PM
Quick Reply: Gear fluids, reading about ATF in the gear case?
