I guess I am a dummy!
The keyless bikes come witha circlular type of key, my 2014 night rod special had this, i killed my bike's battery first night as i turned off the bike, only to realize i actually just turned it back to ACC.
The new keyless bikes do come with keys and you can start them without a key even if you know your code (for when the keyfob battery dies), but i stupidly just turned off the iognition switch one click instead of 2. my new xl1200t does not have an keyless system thank goodness, i dont like the way harley implemented it.
My bike has no ignition switch, no key except the fork lock key....that's why it is called keyless and is a $350 option on the bike.
Are you guys talking about the key fob for the alarm system? I've never heard of a keyless ignition on a Harley. Maybe I'm behind in my knowledge of resent changes. AFAIK, Sportsters come with a regular-looking, flat key for the ignition and fork lock. V-Rods and Big Twins come with a barrel key for the ignition and fork lock. Unless it's hotwired, every Harley I've come across needs a key to turn the ignition on, thereby allowing the bike to start. The ignition key has always been independent of the alarm key fob.
EDIT: Typing at the same time, I guess. I did not know a keyless ignition was an option for 2014 Sportsters. That option is not listed on Harley's web site. There is a Security option listed. Is the keyless ignition bundled with the Security option? It used to be the Security option only included a new module for the turn signals and a key fob (button style early, non-button fob for the past few years). Is it possible your dealer offered and installed an in-house option?
Yes, the keyless ignition is a $350 option on the 2014 sportsters. Your bike obviously does not have the option. My bike came with it. I also have ABS which is another option on the 2014 Sportsters.
On the dealers floor my bike was the only one that had all the options installed. The others did not (no ABS, no Keyless). Harley website lists the options available on the 2014-15 Sportsters.
Are you guys talking about the key fob for the alarm system? I've never heard of a keyless ignition on a Harley. Maybe I'm behind in my knowledge of resent changes. AFAIK, Sportsters come with a regular-looking, flat key for the ignition and fork lock. V-Rods and Big Twins come with a barrel key for the ignition and fork lock. Unless it's hardwired, every Harley I've come across needs a key to turn the ignition on, thereby allowing the bike to start. The ignition key has always been independent of the alarm key fob.
Holy Jeebus! The 2014 Sportsters have a keyless ignition? Did not know that. Do they still give you a key for the fork lock?
I pretty much never use my kill switch. It's always on.
It can be most amusing to reach out with your left hand, just before the light turns green, and hit your buddy's kill switch.
Wait a minute. You left your key on, and it's a 2014? What gives?
A girl at work has a 2014 Sportsters with no ABS or keyless option. She has an ignition key and ignition switch. If you look at my bike where her switch is, I have a bare frame. To turn off the bike, I HAVE to use the "run/off" switch to OFF to turn shutdown the bike, so no worries about accidentally leaving it on. Not like my 2007 Sportster XL1200R.
Keyless is an option. Yes, only a fork lock key. Not all 2014 Sportsters came with the options. My bike had all the options on it at the dealership (keyless, ABS, Hard Candy Volcanic Orange paint). One of the reasons I bought the bike.
Where on Harley's web site does it mention the keyless ignition option for a Sportster? I looked under 2014 Pricing and Specifications. It shows the Color, Hard Candy Color, ABS and Security options. No keyless ignition. Same for 2015.
Not trying to bust your chops. Just trying to see what da Hell is going on. I'm most intrigued by the keyless ignition. Might have to call a dealer, tomorrow.
I know Digital Guard Dog makes a keyless system for Harley for quite a few years
Here is a article about the new keyless option
http://blog.motorcycle.com/2013/08/1...urity-options/
