Broken exhaust stud
Broken exhaust stud
I was trying to take my front exhaust off last night and the bolt was a little rusty so I hit it with some PB blaster before hand. When I came back to remove the nut half of the stud came with it leaving the other half still in the head and it's broke off flush with the motor so there is no welding a nut to it and backing it out. I've done a little bit of research this morning and people are saying to use a Jim's Exhaust Stud Drill Plate Tools Kit. Is this the best option and if so does anyone have one they would be willing to lend me one to use and I'll pay for shipping both ways?
It looks like it just keeps the drill bit aligned, it should be do-able without the tool if you just carefully center punch the bolt and start with a small very sharp bit and work your way up to a larger drill bit to get it big enough to get an easyout into it.
If your real careful you shouldn't hurt the threads in the head, if you do you'll have to put in a helicoil.
Received 47,780 Likes
I’m trying to picture your situation and I'm thinking that something like this might help you. I have a set and it does work great as I had to use it before not on the bike but other things. You might want to give it a try.
http://www.sears.com/craftsman-3-pc-...1&blockType=G1
Grabit Craftsman Deck-Out - YouTube
if you take the head off and take it to a shop they can take the stud out without any issues at all..in the shop where I work we have a machine that will burn the stud out and leave the threads intact...it is actually pretty cool to watch...it has a tungsten straw that has coolant running though it and the tungsten is the electrode for the burn so as it burns out the stud the coolant blows out the molten metal and keeps the casting relatively cool, and it has different diameter 'straws' for different size holes...
John
I got the Jig in the mail today so all I need to do is stop by the dealer to get a stud so I can measure how far I need to drill. The guy that sent me the jig said that you don't have to retap the threads because the bit is the right side to drill out the bolt and then the rest will fall out supposedly.
