Late Model Sportster Front Fenders
Looking for a favor from the XL community
Late model XL bikes using a fender I'd like to install on an older 2002 41mm Wide-Glide front-end.
Years ago, I'd replaced the 21 incher that the bike came with. (I now have a 19" Sporstster wheel), and my stock fender has always looked kind of wierd, as it's narrower than the tire. These late-model fenders (some call them Superlow fenders) seem like they'd cover my tire better. I'd like to purchase one, but not before I know they'd fit.
I'm looking for two measurements; (1) the distance between the mounting points on the lower fork-leg, and (2) from the mounting points to the top of the fender.
Thanks!
Thanks!
Is the front fender on an Iron the same as a fender on a SuperLow? Are they both narrow-glide? The Iron is a narrow-glide. I'm not certain about the SuperLow, either way. It sounds like you're saying the SuperLow has a special fender. In that case, measurements from an Iron may be inaccurate.
In the past, Harley used the same fender for a narrow-glide, regardless of wheel diameter (21" vs. 19"). You could use a fender from a pre-'06 Low Rider or Super Glide on a Sportster.
Just need the distance between the bolts on a lower fork-leg to see if it would bolt onto my '02 41mm Wide-Glide fork-lowers.
My ultimate goal is to use Superlow wheels (and it's front fender) on my Softail.
From a 2014 XL1200C
On my 2014 XL1200C I measure 2 3/4 inches between the hole centers on the fork that attach the fender to the fork, 6 inches between the left and right side fork fender mounting bosses and 4 1/4 inches from the center of the attachment holes on the fork to the top of the fender.
Background:
10 years ago I replace the 21” stock wheel/tire with a 19” sportster wheel. The stock Wide-Glide fender fit funny, but not bad enough to look at replacing it. Now I’d like to replace the 19” with an 18” incher from a Superlow. Not only is my fender too narrow to fit between my stock uprights, it would look even weirder than what I’ve got now.
Here's a pic of my bike in it's current state:
You can see how the fender is actually narrower than the 110/90 19 tire. Looks a little funny, and it's way to tall for a 120/70 ZR18 superlow tire...
Mounting points of 2 3/4 inches is exactly what the ’02 Wide-Glide 41mm fork mounts are!
The Superlow Mid-Glide fender is about an inch narrower than my Wide Glide fork, so I’ll build some ½ spacers to make up the difference.
A Superlow 120/70 ZR18 tire is almost an inch smaller in diameter to my current tire (110/90-19) so this means your measurement of 4 1/4 inches is about right when compared with my current fender (5.6”) which was already a bit too tall for my current 19” wheel.
