My 2013 Iron 883 Cafe Build.
#102
Build Sheet
Here is a build sheet for the bike. If anyone wants part numbers or where to buy for anything just let me know and I can get them for you.
Build Sheet:
Wheels and Brakes
Front:
Roland Sands Design 19"x2.15" Diesel Contrast Cut Front Wheel w/ Avon RoadRider 100/90-19 57V Tire
Roland Sands Design 13" Diesel Contrast Cut Front Rotor
Performance Machine 6 Piston Differential Bore Contrast Cut Front Caliper
Drag Specialties 28 Black Vinyl Covered Stainless Brake line
Drag Specialties 12mm 90* and 10mm 35* Banjo Fittings
14mm Front Master Cylinder from a 2004 XL1200R
Roland Sands Design Black Ops Front Master Cylinder Cover
Rear:
Roland Sands Design 18"x4.25" Diesel Contrast Cut Rear Wheel w/ Avon RoadRider 150/70-18 70v Tire
Roland Sands Design 11.5" Diesel Contrast Curt Rear Rotor
Performance Machine 4 Piston Rear Caliper Contrast Cut with Bracket
Drag Specialties 25 Black Vinyl Covered Stainless Brake line
Drag Specialties 14 Black Vinyl Covered Stainless Brake line
Drag Specialties 10mm 90* and 10mm 35* Banjo Fittings
Drag Specialties T-Fitting for brake sensor
Roland Sands Design Rear Master Cylinder Cover Black Ops
Suspension, Motor and Drive
Suspension:
Burly Brand Front Fork Spring Kit
Burly Brand 13 Stiletto Rear Shocks with Stainless Hex Button Head Bolts
Roland Sands Design Fort Preload Adjusters Black Ops
Motor:
Roland Sands Design Slant 2 into 1 Exhaust The Works
Roland Sands Design Turbine Air Cleaner Black Ops
Vance and Hines Fuel Pak LCD
Custom Trimmed Came Cover with Speed Holes backed with Stainless Mesh
Custom CNC machined Points Cover from Figure Machine
Roland Sands Design Clarity Line Derby Cover Black Ops
Harley Davidson Chain Inspection Cover Wrinkle Black
Roland Sands Design Nostalgia Rocker Box Covers Black Ops
DK Customs Coil and Ignition Relocator
Drive:
Roland Sands Design Pulley Cover Black Ops
Roland Sands Design Front Pulley Guard Black Ops (I added the Stainless Mesh and Brass Badge)
Roland Sands Belt Guard Black Ops (I added the Stainless Mesh and Brass Badge)
Controls and Electrical
Hand:
Roland Sands Design Avenger Levers with Inlay Black Ops
Roland Sands Design Tracker Grips Black Ops
Roland Sands Design Misano Riser Plugs Black Ops
Roland Sands Design Misano Steering Stem Nut Black Ops
Burly Brand Short Cable Kit Black
Harley Davidson Clutch Cable Holders Contrast Cut
Stainless Allen Socket Head Bolts Thru out
Foot:
Roland Sands Design Rear Sets Black Ops
Roland Sands Design Traction Pegs and Shifter Pegs Black
Electrical:
Roland Sands Design Tracker Front Amber LED Turn Signals Black
Roland Sands Design Tracker Fork Mounts Black
Roland Sands Design Tracker Headlight Surround Black Ops (Custom Spacer and lowering for headlight)
Roland Sands Design Tracker Rear Red LED Turn Signals Black (custom Spacers and mounting)
Namz Badlands LE-03 Load Equalizer
Custom ECM Relocation into the battery box
AntiGravity 12 Cell Lithium Ion Battery
Custom Rewire of all lighting and Hand controls Under Tank and Under
Motor:
Harley Davidson Tachometer/Speedometer Combo Gauge with Fuel Sensor
Joker Machine Fork Mount Gauge Relocation Black
Radiantz LED License Plate Frame Black
Body and Paint:
Body:
Roland Sands Design Front Fork Brace Black Ops (I added the Brass Badge)
Harley Davidson Chin Spoiler (Painted John Deer Blitz Black)
Custom Chopped Rear Fender (Painted John Deer Blitz Black)
Custom Chopped Rear Struts
Roland Sands Design Café Enzo Seat Brown/Black
2012 XR1200 Kick Stand Chrome (Painted John Deer Blitz Black)
Vertical License Plate Shock Mount Black
Paint:
Fender, Headlight Eyebrow, Chin Spoiler etc painted with John Deer Blitz Black Rattle Can
Tank, Helmet and Side Covers Designed by me and Painted Bob Hope of Hope Customs
Build Sheet:
Wheels and Brakes
Front:
Rear:
Suspension:
Motor:
Drive:
Hand:
Foot:
Electrical:
Motor:
Body and Paint:
Body:
Paint:
#103
Chris, great looking bike, really impressed with all the work you've done. A couple of questions on parts:
1. What rear view mirror do you have there on the right side of the bike, that doesn't look HD and I didn't see anything on the parts list that looked like that was it.
2. What's the "fin" looking part on the bottom of the frame behind he front wheel? Seen em all over but I don't know what they are called...
3. The tops of your evo are black, did they come that way or is that a swapped out part. I am very newb and don't know what that part of the engine is called so you probably referenced that and I just don't know! Thanks.
#104
Thanks a lot.
The Mirror is the Arlen Ness Mini Oval Black you can find them here:
http://www.arlenness.com/prodcat/Mirror32.asp
The "fin" is called a chin spoiler and it is made by Harley Davidson the part number is 58882-04DH and you can find it here:
http://www.harley-davidson.com/store...-front-spoiler
The tops of the Rockers are indeed after market and they are called Roland Sands Design Nostalgia Rocker Box Covers and they can be found here:
http://www.rolandsands.com/products/...ster-black-ops
Hope that helps
#106
#107
Chris
Just read thru your entire build; pricey, but truly an amazing job! Glad I read carefully, because I was going to comment on your initial choice of suspension. You won't be sorry about switching to the longer Stiletto's. I believe, had you stayed with the slammers in the rear, you would have had nothing but disappointment with the bikes handling characteristics. Correct me if I am wrong, did you keep the slammer front springs? If after riding your current configuration, you find that front travel and handling are less than desirable; you might consider the stock length Progressive front springs. They were the best "bang for the buck" performance mod I put on my build($99). All aspects of handling were improved.
Hope to see more of your cafe, and I'll be sure to check out your build thread on XL. I have found that posting a build thread on more than one forum makes for a richer experience, because observations tend to be different. Which, in turn gives you the builder, broader insight and hopefully a more satisfying project. Again, great build.
Best regards
Rod
Best regards
Rod
#108
Chris
Best regards
Rod
Best regards
Rod
Thanks a lot for the comments Rod. I too am glad I decided on the Stiletto shocks. They are great. Yes I kept the Slammer springs in the front. I wanted to lower the front just a touch and they feel great. The bike really performs and handles exceptional.....for an 883 anyway. I am very happy about it.
I have the same build thread going on XL, ChopCult and HDRidersU.S.A . Only difference is the specific comments and answers from others. The XL one got a little out of control for a little while then the guy got banned. All good now though.
#109
Put a couple hundred miles on her today. The bike ran great and the suspension was awesome. I am starting to push it a little more each ride.
I have to say so far it is sooooo much fun to ride. Since I raised the rear and slightly lowered the front the bike drops into turns much better than before but because it is a little top heavy it takes a litter more effort to stand it back up coming out of the turn than I would like.
Overall I am very, very happy with everything about the bike.
I rode it the other day to work and coming home it was dark and freezing so I just ordered some Venture Heat gear to keep my *** warm.
Here are a few pics from ride today.
Yep thats me.
Lets Go.....
Yep thats me.
Lets Go.....
#110
Chris
Good to know you are pleased with the performance of the Slammer front springs. I have wondered many times if they would be adequate. Any idea on the travel you are getting? How about dive when braking?
I've noticed you're not the only one who has opted to lower the front a tad to improve handling on a sportster cafe build. I may be wrong(I'm sure I'll be corrected if I am), but I think the Burly guys went with a lowered front as well. Not sure what their solution was. Anyway, great photo's in your last post. The wooden barn makes for a nice backdrop.
Rod
Rod
