My 2013 Iron 883 Cafe Build.
Old 10-29-2014, 01:59 PM
chris_b_owens's Avatar
chris_b_owens
chris_b_owens is offline
Now it was time for the fender chop. I must admit it was pretty scary……first time here fellas. Thanks to my wife for the pics…..dramatic effect you know lol
I laid down some tape and used a paper plate to get the arcs that I wanted. Made sure it would hide under the seat and got to chopping.
Fit perfectly!!!!
Old 10-29-2014, 02:08 PM
chris_b_owens
Next was the strut cut.
Now originally I planned on mounting the rear turn signals to the left over struts but ended up mounting them in the fender.
The upper shock bolt holes are threaded all the way thru the frame but the bolt itself just goes about half way. So I decided this would be a perfect way to mount the rear fender. I drilled holes to match the shock bolts and used 1/8th in spacers on either side of the fender to mount from the inside. Very solid.
Old 10-29-2014, 02:49 PM
chris_b_owens
Got rid of the Chainsikle rear sets….never used and got the RSD rearsets. I love the design much better and the placement of the master cylinder is much better.
Next decided to remove the exhaust and bore some tracker holes in the cam cover to match the RSD pulley cover.
Next decided to add some stainless woven mesh behind the holes for contrast and added it behind both pulley and belt guards for uniformity.
Then I wrapped the oil lines and all electrical in the Flexo F6 braided loom. I think it looks pretty good. It is heat resistant up to 257 degrees so hopefully it will hold up.
Old 10-29-2014, 03:00 PM
chris_b_owens
I saw this video on youtube:
I fell in love with this bike. I did some research and found his build thread here:
http://xlforum.net/vbportal/forums/s....php?t=1552801
Fred Phuket’s Nightster…specifically how clean it was inspired me to do almost a complete rerunning / rewiring of the electrical. Plus more that will be posted later….
So with that said. I decided to relocate the ECM and reroute some wiring under the bike.
Old 10-29-2014, 03:09 PM
chris_b_owens
Then I had a custom points cover milled by FigureMachine.com with my family logo. As you can see it came in bare aluminum. I used a wire brush and 3M 400 grit sponge to get rid of the mill marks and soften it a bit.
Next I used some Birchwood Case Aluminum Black to age and darken the piece. Turned out great and goes with the bike perfectly.
Old 10-29-2014, 03:29 PM
grancuda's Avatar
grancuda
grancuda is offline
That's the easiest way, in my opinion, to do a cafe style since RSD came out with that seat. I was going to do the Mustang version of that seat & cut it the same & still will if I put rear suspension back on my bike. Looks good IMO.
Old 10-29-2014, 05:43 PM
chris_b_owens
I don't know if it is the easiest but I do like it the best. I really like the shape of the cowl on the seat, but its a must IMO to cut the fender to match. Just sitting it on the fender as designed does not have the same effect.
The other options are to replace the seat pan and rear fender with some kit. I don't like this option as much because most of the kits out there are just too small or too blocky. RSD has just released there café rear section which looks really good and was certainly an option but I am liking where mine is going so far.
Old 10-29-2014, 05:44 PM
chris_b_owens
Ok here is the paint progress so far. Hopefully the guy will be done soon. He still needs to finish the lettering but as you can see he has masked it and sprayed the brass metallic.
Tank
Oil and battery covers
Bell Custom 500 Helmet
Old 10-29-2014, 06:20 PM
chris_b_owens
Other parts installed:
Repainted (John Dear Blitz Black) rear fender with RSD rear Turn Signals. Now since I have not had a battery hooked up since I started all of this. I have no idea if/how all of this will work. Obviously the Irons have the Brake/Turn/Run system for the tail lights. The RSD Led Turn signals are 3 wire set up so I am hoping at most I will just need a load equalizer at worst since I have no brake light I may have to buy a Brake/Turn/Run module from either custom dynamics or badlands.
As you can see by the rubber grommets I will be mounting the seat from underneath using some T nuts and drilling out under the seat pan of the seat. I am just waiting to get the tank back from paint to ensure proper fit.
Joker machine LED Speedo fork relocation with the HD Speedo / Tach combo
RSD Front turn signals with fork mount clamps
Old 10-29-2014, 09:11 PM
Ployd4's Avatar
Ployd4
Ployd4 is offline
Nice work! I can't wait to see it done. It's the little details that really add to it.
Quick Reply: My 2013 Iron 883 Cafe Build.
