My 2013 Iron 883 Cafe Build.
Wow thanks a lot. If you can tell by my garage I am a wood worker at heart. I build custom high end poker tables with dining conversions and other furniture. This is my first attempt at mechanics. I have had numerous cars and bikes and customized most but never to this level.
Thanks for the compliments on the paint. I just painted the rear fender and front headlight brow. I had the other stuff done by a pro.
Thanks a lot!
_________________
More pictures of the wire tuck and ECM Relocation. I was only able to relocate it like this because I bought the Antigravity 12Cell Lithium Ion battery. This thing is really tiny. With all that extra room I was able to get the battery, ECM, fuse box and extra wiring stuffed in there. Its not pretty right now but I will clean all of it up more later.
Here is pretty much where she sits right now. I am just waiting on the tank and side covers to make everything fits.
Once I get the paint back I will be able to mount the seat, make sure all the wiring fits and make sure she fires up. I will have some programing to do with the new speedo. I have to install the fuel level sensor in the tank. I will probably have to install a load equalizer for the turn signals.
My new toys came in today. I am going to wait to install these until I get the paint back and ride this girl.
Roland Sands Diesel Contrast Cut Wheels 21x2.15 front and 18x4.25 rear will be wrapped in Avon Roadrider Tires. Matching 13 Rotor for the front and 11.5 for the rear
Performance Machine 4 piston Rear Caliper for the rear and 6 piston for the front,
Performance Machine Contour Hand control complete set
Drag Specialties Custom Black stainless brake lines and fittings.
Thank you
_____________________
Parts list with part numbers if anyone is interested.
I bought most aftermarket parts either from Revzilla or Direct Cycle Parts. All OEM parts as well as the Drag Specialties brake lines were purchased from New Castle HD online....
I used Revzilla's price match alot and they were always pretty awesome about it.
RSD Slant 2 into 1 Stainless Exhaust
1800-1560
RSD Enzo Cafe Seat
0804-0446
RSD 39MM Clip ons Black Ops
0601-1838
RSD Fork Brase Black Ops
0415-0022
RSD Avenger Levers Black Ops
0610-0595
RSD Belt Guard Black Ops
1202-0092
RSD Riser Hole Plugs Black Ops
0603-0437
RSD Misano Fork Adjuster Black Ops
0414-0448
RSD Misano Stem Nut/Bolt Black Ops
0410-0188
RSD Cafe Gas Cap Black Ops
0703-0339
RSD Rear Master Cylinder Cap Black Ops
1731-0287
RSD Rear Sets Black Ops
1623-0187
RSD Tracker Rear Turn Signals Black
2020-0607
RSD Tracker Front Turn Signals Black
2020-0605
RSD Turn Signal Fork Mount Black
2020-0633
RSD Tracker Headlight Bezel Black Ops
2001-0798
RSD Tracker Grips Black Ops
0630-0949
RSD Front Master Cylinder Cap Black Ops
0610-0328
RSD Derby Cover Clarity Line Black Ops
0940-1191
RSD Nostalgia Rocker Box Covers Black Ops
0940-1144
RSD Turbine Air Cleaner Black Ops
1010-0964
RSD Tracker Pulley Belt Guard Black Ops
1202-0092
RSD Front Pulley Belt Guard Black Ops
1202-0102
RSD Front Pulley Cover Black Ops
1201-0720
RSD Brass Badge Kits
4320-1449
RSD Diesel 21x2.15 Front Wheel Contrast Cut
0201-1585
RSD Diesel 18x4.25 Rear Wheel Contrast Cut
0202-1736
RSD Diesel 13" Front Rotor Contrast Cut
1710-0372
RSD Diesel 11.5" Rear Rotor Contrast Cut
1710-0374
Performance Machine 4 Piston Rear Caliper
1701-0479
Performance machine 6 Piston Front Caliper
1701-0305
Performance Machine 9/16 Master Cylinder
0610-0236
Performance Machine Clutch Lever
0612-0323
Performance Machine Left Side Switch Housing
0616-0099
Performance Machine Right Side Switch Housing
0616-0097
Performance Machine Throttle Assembly
0632-0424
Performance Machine Clutch side Spacer
0011-1000MP-B
Avon Roadrider AM26 Rear - 150/70-18 70V
2276513 / 90000000669
Avon Roadrider AM26 Front - 90/90-21 54V
2268113 / 90000000657
Drag Specialties Brake lines
Various
Vance & Hines FuelPak
1020-2023
Burly Slammer Kit Black
B28-1001B
Burly Cable Short Kit
B30-1099
Joker Machine Speedo Relocation
2210-0153
Antigravity 12 cell Lithium Ion Battery
AG-1201
HD Brand Front Chin Spoiler
58882-04BDK
HD Brand Speedometer
70900274
HD Brand Fuel Level Sensor Kit
61200008
HD Brand Inspection Cover Wrinkle Black
34794-05A
Mo-Door Garage Door Opener
Vertical Side Mount License Bracket Black
LED Tag Bolts Black
Custom Milled Points Cover Bare Aluminum
FigureMachine online
O2 Eliminator Kit
Stainless Mesh
Flexo F6 Covering
Everyone hates on the price tag of the RSD stuff but their parts look so great its really hard to choose something style wise, especially going for a cafe style, over them. Loving the build so far! Do you intend on spraying that little bit of rear fender that is slightly visible under the seat? Not really necessary as its barely noticeable at all but just curious. Those rims are beautiful!
Not trying to be rude, and you do not have to respond to this, but I'm curious as to how much you are spending for the build and bike? I'm always so curious as to how much everyone ends up spending on their builds, mostly so I can have a kind of goal or expectation to eventually go for whenever I can finally scrounge up some money.
