Air Shocks
you are a new guy so we will let this go...do a search of this forum and you will find a good amount of threads on this subject..but basically they all say that the ride is vastly improved (I agree) and it is a cheap upgrade if you buy used...and it is easy to do...
as far as washers, you can go to homedepot or the like and just buy a half dozen or so that will fit the mounting bolt..I find that when changing the shocks if you hang the rear end a inch or so from the ground and remove the shocks (the rear will fall to the floor) then install just he bottom bolts on both shocks and raise the rear swing arm (or lower the bike lift) until the shock holes are lined up with the mounting holes in the frame you can see how much of a gap there is to fill with washers and if the shocks rub anywhere you can add washers either bottom or top to bring the shocks away from frame etc...the only thing to look out for if that you don't want the shocks to be at a angle away from the bike and bind on the bolts (you may have to add washers both top and bottom to spot this from happening)...sounds tough, but it really a very easy job..
Does anyone see any trouble doing this? I have a set of Road King shocks I will be installing on my Custom shortly. I have an air line kit on order from HD and I still need to get oil. The shocks look new. They have plugs in the air ports.
Just got the shocks in, box had a bunch of oil in it, so looks like I have no choice but to drain them then refill with oil.
Draining them is just as easy hanging them at an angle for a couple days correct?
Also was looking at lowering blocks, they have some on the Bay that are 1-3 inch adjustable. Anyone use them? Also would 3 inches be too low? I know the shock are an inch longer, but really like the lower look.
blue mines lowerd 3 inchs no problem at all it almost seems stock to me !
build a rig
drain the oil out of them and refill them with heaver shock oil. AMSOIL Shock Therapy 10wt. 10 oz would be standard..
- remove the air line
- place the shock upside down in a jig.
- pump the shock several times to empty the existing oil
- turn the shock right side up
- insert funnel in tubing and pour new oil into funnel
- gently pump shock to force air up through tubing and funnel and allow the vaccum to pull oil back into shock.
- mount shock back on bike, replace air fitting with thread sealer, or teflon tape trim air hose and insert back into air fitting.
i will post some1 else rig i found online one minute
build a rig
Elf what lowering blocks did you use? How does it ride? Ever bottom out or anything?
Also if the shocks are 1" longer wouldn't using a 3" lowering block really only be lowering it 2"?
These are the ones I am talking about.
http://www.ebay.com/itm/09-10-11-12-...aec311&vxp=mtr
