2008 ignition switch issue or
My 2008XL got light up in speedometer when I switch to ACC.
When I further switch to IGNITION position, no difference. I mean the headlight is not on, neither the neutral , oil and battery light.
Could this cause by bad switch? Anyway I can bypass the switch easily without taking off the tank?
Thanks for any help in advanced..
Hank
Hank
End up I got bad ignition switch. The headlight will eventually turns on when I rock my key in the IGNITION position. I guess my heavy key chain causing this issue.
I am researching to replace the switch. I see some selling dyna-style (round key) switch for sportster on eBay. But no clue if it allows me to pull out the key as dyna after I switch to the ignition position also.
Here are the questions I am looking for answers
1) if I replace it with OEM, is it possible I can get one that I can use my old key? Do not like to carry two keys on the road
2) For the after-market switch, which one has good reputation and also can bolt-on to replace the old one directly ...
Thanks for any help for these two questions.
Read through this... My breakdown of your ignition switch swap....
https://www.hdforums.com/forum/sport...nder-35-a.html
nashvegasmatt,
thanks for the info. Question for the switch you got. Can you move out the key after turning it to on position? Thanks
nashvegasmatt,
